Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... , 33, 34, 35  Next
majB
PostPosted: Sat Jan 23, 2010 9:43 pm    Post subject: Reply with quote
[/quote]
It's possible to make the "Next Route Event" (as Nav'n'Go call it) transparent but in my opinion it makes it harder to read so I haven't included this option.
linknet[/quote]
Thank you for the quick answer.
actually I like your skin; it is the only skin beside the default, that does not crash my nav when using TMC.
I was trying to make the "Next Route Event" background transparent using the igo skin editor, but had no luck till now, so I thought; ask the master!
So please can you give me a hint.
Thanks in advance..!
linknet
PostPosted: Sat Jan 23, 2010 11:01 pm    Post subject: Reply with quote
majB wrote:
I was trying to make the "Next Route Event" background transparent using the igo skin editor. So please can you give me a hint.
It's a long time since I worked on this so it may not be correct !
In the "navigatemap_320_240.ui" file locate the following section:
;!MOD_FSM - Replaced route navigation layer for full screen mode
{layer ui_NavigateMapRouteNavigation z=51}
{BUTTON sprNMRCockpit x=0 y=0 z=1 bmp="cock_infobg1_full.bmp" visiblemodel="!ui.v3dzoomcontrol" onlongclick='run sc_ShowCockpitDetailDirInfo1' onrelease='NEXTSTATE st_RouteInfo' enabledmodel="!ui.vDiriconVisible&!ui.vOnFlyover" CHECKHIT}
You need to make the BUTTON transparent by adding "alpha=16" to that line where 0 is totally transparent and 32 is totally opaque.
Something like:
{BUTTON sprNMRCockpit x=0 y=0 z=1 bmp="cock_infobg1_full.bmp" alpha=16 visiblemodel="!ui.v3dzoomcontrol" onlongclick='run sc_ShowCockpitDetailDirInfo1' onrelease='NEXTSTATE st_RouteInfo' enabledmodel="!ui.vDiriconVisible&!ui.vOnFlyover" CHECKHIT}
There are a further 5 lines in the file containing "cock_infobg1_full.bmp" of which the first 4 will need similar modification, the 5th line is already transparent.
Best of luck !
linknet
majB
PostPosted: Sun Jan 24, 2010 3:41 am    Post subject: Reply with quote
It worked!....Thanks a lot.
TheGrumbler
PostPosted: Mon Feb 01, 2010 9:43 am    Post subject: Re: New version + DA Reply with quote
linknet wrote:
I'm hoping that at some point Nav'n'Go will redesign the iGO8 interface to be comparable with the Amigo interface. Therefore I've put the iGO8 Ultra Skin on hold for the time being.
What a pity!
But anyway "iGO 8 Ultra Skin 6.0.22" is obviously still compatible with the newest PDA version 8.3.2.124260 dated Dec 16, 2009.
TheGrumbler
linknet
PostPosted: Mon Feb 01, 2010 3:48 pm    Post subject: Re: New version + DA Reply with quote
Not necessarily, the iGO 8 Ultra Skin 6.0.22 is based on the data.zip from iGO8 PDA Version 8.3.2.87762 dated 27th April 2009, therefore if the newest PDA version 8.3.2.124260 dated 16th December uses a different data.zip, which it does, then there may be conflicts.
linknet
TheGrumbler
PostPosted: Tue Feb 02, 2010 2:45 pm    Post subject: Re: New version + DA Reply with quote
Hi linknet,
Up to now I didn't experience any incompatibilities between your UltraSkin6.0.22 and the data.zip of iGO 8.3.2.124620.
TheGrumbler
linknet
PostPosted: Tue Feb 02, 2010 4:53 pm    Post subject: Re: New version + DA Reply with quote
TheGrumbler wrote:
Hi linknet,
TheGrumbler
That's good, if you do find anything then please let me know. Wink
linknet
gachbash
PostPosted: Mon Feb 08, 2010 6:17 pm    Post subject: how to get the lane arrows at the bottom Reply with quote
Hello all!
When navigating with iGO8+ Ultra Skin 6.0.22,
I have the signposts on top of the map,
but no lane arrows at the bottom of the screen...
(with dimka skin i have the bottom lane arrows)
please help!
linknet
PostPosted: Mon Feb 08, 2010 7:50 pm    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
gachbash wrote:
Hello all!
please help!
They're mutually exclusive with the signposts having priority.
linknet
gachbash
PostPosted: Mon Feb 08, 2010 9:06 pm    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
linknet wrote:
gachbash wrote:
Hello all!
please help!
linknet
Now i see it!
I am looking for a user guide for the skin.
I like the skin very much. clean and clear on C310 Mio.
Still have few questions:
How can i hide the driving speed and speed limit on the left side?
How i access the full screen mode?
Thank you!
linknet
PostPosted: Mon Feb 08, 2010 9:28 pm    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
gachbash wrote:
1. I am looking for a user guide for the skin.
2. How can i hide the driving speed and speed limit on the left side?
3. How i access the full screen mode?
Thank you!
1. There isn't a user guide but check out the website, in particular the screenshots page.
2. On the "Speed Warning Settings" menu.
3. It should always be in full screen mode when used in landscape as on Mio C310.
linknet
gachbash
PostPosted: Mon Feb 08, 2010 10:32 pm    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
Thank you!
linknet
Thank you for the 3 answers.
still,
-If i uncheck the Speed Warning box, would the alarms work when i am overspeeding?
-I saw a screenshot of a full screen mode and on the right it was clean (no option buttoms except 2d/3d). How it is done?
linknet
PostPosted: Mon Feb 08, 2010 11:04 pm    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
gachbash wrote:
1. If i uncheck the Speed Warning box, would the alarms work when i am overspeeding?
2. I saw a screenshot of a full screen mode and on the right it was clean (no option buttoms except 2d/3d). How it is done?
1. Is that the "Audible Warning" box ??
2. That's only in route simulation mode.
linknet
gachbash
PostPosted: Mon Feb 08, 2010 11:37 pm    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
linknet
-in "Map Screen Setting" there is Trip Data Overspeed Warning check box.
-In "Warning Settings" there is Warn when Speeding check box and in the submenu there are Show Speed and Show Speed Limit check boxes.
It would be nice to have the audible warning when over speeding without seeing the visual display of the speed or the speed limit (i still see the speed in the car counter and the limit is normally known)
linknet
PostPosted: Tue Feb 09, 2010 12:04 am    Post subject: Re: how to get the lane arrows at the bottom Reply with quote
Then just turn off "Show Speed" and "Show Speed Limit" in the submenu.
linknet
Page 34 of 35
