Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 32, 33, 34, 35  Next
kostaschrys
PostPosted: Thu Jan 07, 2010 9:28 pm    Post subject: Reply with quote
Hi linknet,
Thanks for the help. I created the button and works fine. I made a new data.zip with the modifications. The only problem I have is that the mouse pointer is always visible on I go navigating screen. Any idea how to hide it.
Regards
Kostaschrys
linknet
PostPosted: Fri Jan 08, 2010 12:06 am    Post subject: Reply with quote
kostaschrys wrote:
Hi linknet,
Regards
Kostaschrys
That's good. Smile
When you say "mouse pointer" is that actually a mouse pointer or is there something lost in the translation ?
Regards
linknet
kostaschrys
PostPosted: Fri Jan 08, 2010 12:40 pm    Post subject: Reply with quote
Hi linknet,
Indeed a real mouse pointer, a working one, where you press with your finger moves with it. Probably it is hidemouse=1 text, somewhere on my data modifications and I get that.
Any idea?
Regards
Kostaschrys
kostaschrys
PostPosted: Fri Jan 08, 2010 12:44 pm    Post subject: Reply with quote
Hi linknet,
Any idea?
Regards
Kostaschrys
kostaschrys
PostPosted: Fri Jan 08, 2010 12:45 pm    Post subject: Reply with quote
Hi linknet,
Any idea?
Regards
Kostaschrys
kostaschrys
PostPosted: Fri Jan 08, 2010 12:48 pm    Post subject: Reply with quote
Hi linknet,
Any idea?
Regards
Kostaschrys
linknet
PostPosted: Fri Jan 08, 2010 12:57 pm    Post subject: Reply with quote
kostaschrys wrote:
Hi linknet,
Kostaschrys
I've not heard of that before, quite useful if you're not using the device for navigation. Out of interest which device are you using and is the mouse pointer part of the operating system.
I don't know how you would disable it though.
Regards
linknet
kostaschrys
PostPosted: Fri Jan 08, 2010 6:54 pm    Post subject: Reply with quote
Regards
linknet[/quote]
I am using a car navigation box, that support navigation and other windows CE players. THe box is called navibox OS 500 I think.
I found the solution to the pointer
There is a file in data:
Data\config\devices\wonderproud.ini όπου where inside has:
[interface]
maxzoom2d=6000000
show_exit=1
hide_mouse=0
Changing to hide_mouse=1 the pointer is disabled.
Regards
Kostaschrys
linknet
PostPosted: Fri Jan 08, 2010 8:38 pm    Post subject: Reply with quote
kostaschrys wrote:
I found the solution to the pointer:
Regards
Kostaschrys
All problems solved then. Wink
Regards
linknet
JackDo
PostPosted: Thu Jan 14, 2010 8:50 am    Post subject: New version + DA Reply with quote
Using your skin for a long time and would not like to replace it.
I have Loox N560 with 640x480 (portrait).
Will you support the new release 8.3.4.117940 and _da?
linknet
PostPosted: Thu Jan 14, 2010 12:11 pm    Post subject: Re: New version + DA Reply with quote
JackDo wrote:
I'm hoping that at some point Nav'n'Go will redesign the iGO8 interface to be comparable with the Amigo interface. Therefore I've put the iGO8 Ultra Skin on hold for the time being. By the way, what is DA ?
Regards
linknet
PostPosted: Thu Jan 14, 2010 12:15 pm    Post subject: Re: New version + DA Reply with quote
It's Driver Alert. Used with only Navtech maps. Gives alerts for schools and lots of other stuff. No so many signposts in NT maps though
linknet
PostPosted: Thu Jan 14, 2010 12:30 pm    Post subject: Re: New version + DA Reply with quote
Thanks for that. I knew that driver alert was included in 8.3.4.117940 so I should have realised that DA was the acronym. Rolling Eyes
Regards
linknet
majB
PostPosted: Sat Jan 23, 2010 3:28 pm    Post subject: Reply with quote
Is there away to make the background of the cruise arrows transparent (the upper left corner).
In a PNA of 320x240 it is eating about 1/4 of the screen. I thought making the background transparent will improve the visibility of the map just like in the Dimka skin.
thanks!
linknet
PostPosted: Sat Jan 23, 2010 7:09 pm    Post subject: Reply with quote
thanks!
It's possible to make the "Next Route Event" (as Nav'n'Go call it) transparent but in my opinion it makes it harder to read so I haven't included this option.
linknet
Page 33 of 35
22.062 (12 Jun 24)
