Pocket GPS World :: View topic - Installing speed camera data base on Nav N Go iGO
snowyjp
PostPosted: Thu Dec 10, 2009 11:18 pm    Post subject: Installing speed camera data base on Nav N Go iGO Reply with quote
I have a Nav N Go iGO GPS and need to install the speed camera data base i have followed all the instructions without success can any one help me
Snowy jp
BigPerk
PostPosted: Fri Dec 11, 2009 1:02 am    Post subject: Reply with quote
First of all - HAVE you subscribed to the database Rolling Eyes ?
If 'yes' then can you be more specific about the way in which you were unsuccessful Confused
IE what instructions did you actually follow (whatever steps you can remember) and what happened/didn't-happen-that you-expected?
Incidentally, I suggest you carry on this in
data downloads
where you started it. Saves duplication and confusion and should get you a quicker answer.
MOD EDIT:
BigPerk wrote:
Incidentally, I suggest you carry on this in 'data downloads'.....
Good idea David, but in this case it did continue here, so I'll lock the other one instead. Smile - Andy_P.
(Navigon 70 Live, Nuvi 360)
snowyjp
PostPosted: Fri Dec 11, 2009 8:02 am    Post subject: Reply with quote
data downloads
Thanx for ur reply
First Yes I subsribe to the data base downlods
I downloaded the data base into unzipped and followed the installation guide supplied by pocket world could not use Active Sync so i dragged and dropped the files into iGor 8
i went into settings on the GSP then into warnings the safety camera loaded after about 5 min on road testing it did not work
i tried all the folders ( iGo8 ,Content , But no results
I hope u can give me another way to load the data into the GSP
Thanks again
Snowyjp
PostPosted: Fri Dec 11, 2009 9:41 am    Post subject: Reply with quote
The .txt file should go in the IGO8\Content\Speedcam folder. When you restart IGO, it should pause on something like 'INITIALLISING SAFETY DATA'. Ther should already be a .scdb and a .spud file in this folder
snowyjp
PostPosted: Sat Dec 12, 2009 12:18 am    Post subject: Reply with quote
Hi thanks for your response but so far no luck the data folder is a zip the speed camera mode does not appear in the warning setting any more
is the a way to get it back
Is there a way to load Garmin safety camera data into my unit i tried but got a message it has to be a gpx life it is a gpi
Snowyjp
PostPosted: Sat Dec 12, 2009 2:49 am    Post subject: Reply with quote
you will need to extract the contents of the zip file.
a garmin file won't work in igo. the garmin gpi file is a custom file for garmin. igo requires plain text as per our downloads for igo.
snowyjp
PostPosted: Sat Dec 12, 2009 4:22 am    Post subject: Reply with quote
Hi Again I did all but still no alerts was it oK to drag n drop the data files into the IGO8 folder or do i need an installer mmmmmmm nearly ready to give up
or do i start all over again
Regards\Snowyjp
PostPosted: Sat Dec 12, 2009 10:01 am    Post subject: Reply with quote
Don't do that. We'll crack it
Yes, That's OK.
Lets have a review.
You need to unzip the .txt file from within the downloaded zip file. It's called pocketgps_uk_sc.txt and the current uk one is 297,515 bytes.
You then need do drag and drop this file into the IGO8\Content\Speedcam folder. This folder is not zipped, and it's not in the data.zip file.
Restart IGO and it should pause during loading as I said above.
The controls to enable speedcam alerts will not be displayed until you have a satelite lock with the standard skin. If you are in Switzerland, they will not appear at all, as it's illegal to use them there.
snowyjp
PostPosted: Mon Dec 14, 2009 6:20 am    Post subject: Reply with quote
Yes, That's OK.
Lets have a review.
Hi OK i dropped the text file into speed camera folder there is only one file in there it is SpeedCamUpdates SPUD file 1kb is that ok
I am in Australia so the download is aust/nz
thnx
PostPosted: Mon Dec 14, 2009 10:14 am    Post subject: Reply with quote
thnx
That sounds OK. When Igo starts, it should read the new .txt file and convert it into a .scdb file for IGO to actually use. I assume that you are running it from an SD Card, otherwise there could be a conflict between the stuff in internal memory and stuff on the SD. Latest Aus file is 51255 bytes when unzipped.
As an afterthought. Upload the spud file to your PC and check the size. Put a couple of dummy local user speedcams into the device. Re-upload the spud file and see if it's bigger and thr date has changed, if so, this will verify thet IGO is using the location in which you have fround the spud file.
snowyjp
PostPosted: Tue Dec 15, 2009 12:18 am    Post subject: Reply with quote
thnx
i am sorry to being a pain i opened the camera update file (spud) it was all encrypted words
it seems the text files have to be converted to a spud file
that is not happening
I followed all the installation guides supplied by pocket
in Ebook the files are there so what we need is the txt files converted to spud ( i think)
i am at a loss sorry
Is it possilble to use garmen POI to install the data base
PostPosted: Tue Dec 15, 2009 9:28 am    Post subject: Reply with quote
It's not encrypted, it just uses wierd units, so looks like it's encrypted
The text file is not converted to a spud file, it should be converted to a spdb file. The spud file contains user input cams from the add camera function of IGO.
No, I don't think so.
Have you done/ investigated what I suggested in my previous posts?
If so, please post the results so that we can progress this.
Just had another thought. What version of IGO and PDA/PNA are you using. There might be differences Shocked
snowyjp
PostPosted: Tue Dec 15, 2009 9:24 pm    Post subject: Reply with quote
Ok
I uploaded the spud file which is the update file to microsoft word the icon changed to a word icon
it had no content i put a couple of speed cameras on the map i then put the spud file back in and it did not change is that what u wanted
there is no scdb file there
the version is a 2006 model
do we need to change the text file to a scdb
Snowyjp
snowyjp
PostPosted: Tue Dec 15, 2009 10:08 pm    Post subject: Reply with quote
Ok
Snowyjp
i did it again i put a camera on the map and dragged the spud file to the desk top it change to a 1 kb content so i dragged it back into speed camera
snowyjp
PostPosted: Wed Dec 16, 2009 12:39 am    Post subject: Re: Installing speed camera data base Reply with quote
Snowy jp
would it be possible for u to convert the speed camera dat base from txt to spdb file and send to me to upload
