Pocket GPS World :: View topic - Post Code Search
Post Code Search
djc1610
PostPosted: Thu Nov 05, 2009 11:41 pm    Post subject: Post Code Search Reply with quote
I recently boughtb a GO 730 after ditching an old MIO A201 with Navigator 6.
I have purchased another map (New Zealand) and I have placed the new map onto a SD card. To gain space on the internal memory I have move the map of Europe over to the SD card.
The 730 fires up OK and seems to work OK except for one problem. It will only do a 4 character Post Code search. To check this I have gone to Browse Map, then Find, then Post Code and tried to enter a full Post Code but it will only find the first half.
I have placed a file called Tomtom in the root directory of the SD Card and the Internal memory but it still does not work.
Do i need to add any Post Code files or what else must I do?
PostPosted: Thu Nov 05, 2009 11:47 pm    Post subject: Reply with quote
Is there a folder named "zip" on the device or the memory card, and if so are there any files in it? as it sounds like this is missing to me - Mike
PostPosted: Fri Nov 06, 2009 10:56 am    Post subject: Reply with quote
Is this for UK or NZ that you are trying the post code search?
djc1610
PostPosted: Fri Nov 06, 2009 10:58 am    Post subject: Post Codes Reply with quote
The UK
Also there is no folder called zip on either SD card or internal memory. How do I get hold of this folder?
Thanks to you both.
Daggers
PostPosted: Fri Nov 06, 2009 12:19 pm    Post subject: Reply with quote
This thread explains where to find the files.
Garmin DriveSmart 50 LMT-D
djc1610
PostPosted: Sat Nov 07, 2009 10:07 pm    Post subject: Post Codes Reply with quote
Thanks to all I have at last sorted it all out
well nearly all of it out.
How do I know that I have got the latest release of the Post Code files?
PostPosted: Sat Nov 07, 2009 10:18 pm    Post subject: Reply with quote
If you have installed the files from Oldboys web site then you have the most upto date that are currently available, the newer devices might have something newer installed but AFAIK these newer files are only available with the purchase of a new device, no download/ update of the very latest files are currently available - Mike
PostPosted: Sat Nov 07, 2009 11:12 pm    Post subject: Reply with quote
Question for Darren really. There are constant rumours that the (latest) v801 postcode files have been superseded, but still no sign of release from TomTom. I'm now getting more and more instances of TT device not finding a postcode when I can find it using Royal Mail's website (e.g. BS32 4JA). Trouble is, that's not much use when you're on the road and not sitting at a PC to look at Royal Mail website.
Any chance of you using your good offices with TomTom to ask what the prospects are, please?
PostPosted: Sat Nov 07, 2009 11:14 pm    Post subject: Reply with quote
I'll pose the Q first thing Monday.
22.055 (29 May 24)
