fluke9 Lifetime Member
Posted: Fri Sep 25, 2009 4:13 am Post subject: Latest WCE 2GB Maps Don't Fit On Internal Memory of 730 ???? |
I have heard the latest version WCE 835 2419 does not fit on internal memory of Go 730 anyone know if this is true ???
Tomtom Customer Service are about as much use as a chocolate teapot when asking about this stuff.
And all links seem to point to dodgy stuff when googling. _________________ TTGO730
App 8.351 (9982/090518) OS:315187
GPS v1.20, Boot 5.5120
Map WCE 845.2645
iPhone 4S 3 (Contract)
Dave. |
zzr1200 Lifetime Member
Joined: Jun 05, 2005 Posts: 205 Location: Gloucestershire
Posted: Fri Sep 25, 2009 7:23 am Post subject: |
I have a TT720 rather than a 730 and I could NOT fit the lastest W&CE map onto my internal memory. I have therefore downloaded it to a 2GB SD card and use that in the TT.
Good luck. |
Posted: Fri Sep 25, 2009 8:27 am Post subject: |
What you can do is a manual install of the downloaded map:
1/ Unzip the downloaded map to a known location on the PC
2/ Open the folder containing the extracted files
3/ Delete the cspeech_XYZ.dat files EXCEPT cspeech_GBR.dat
4/ Copy the folder to your TomTom
The above method means you won't have speech recognition working in anywhere other than the UK, if you don't use voice recognition at all then you can delete all the cspeech files including the GBR file, this would save you 217MB in storage capacity - Mike |
DennisN Tired Old Man
Posted: Fri Sep 25, 2009 8:36 am Post subject: |
Try the download first and see if it works.
Do a full backup using Windows Explorer, then go for it. In some cases, the new 835 map has simply overwritten the old map without running up against the space problem. You never know, you could be lucky! _________________ Dennis
Two of them are obesiting!! |
MickeyM Lifetime Member
Joined: May 12, 2005 Posts: 216 Location: Norfolk UK.
Posted: Fri Sep 25, 2009 9:31 am Post subject: |
Why do Tomtom make memory so tight. Why not make the units with larger memory? Came across this with my cousins 730. |
Posted: Fri Sep 25, 2009 11:10 am Post subject: |
I think the problem is actually the maps getting bigger that's the problem. I think that this latest map is the third map I have had on the 720 and each map is bigger than the last. Also, don't forget that the 720 (and 730 I think) was designed for the WE map, not the W&CE map. SD cards are so cheap nowadays that if you still want the speech files, it will onlt cost you a fiver to get a 2gb card, a few quid more for a 4gb card and have space for some music files as well.
Good luck. |
alan_sh Lifetime Member
Posted: Fri Sep 25, 2009 11:38 am Post subject: |
To answer the original question - yes they do. I have a 730 and the latest WCE maps.
Alan |
dhn Frequent Visitor
Posted: Fri Sep 25, 2009 11:46 am Post subject: |
We're faced with the same problem with the North_America_2gb maps. A complete hassle trying to get them to fit into internal storage. A 4-gig sdhc card was the only way to go for me. _________________ David |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Fri Sep 25, 2009 12:19 pm Post subject: |
Hi fluke9
I do not have the 730 but I do have the 720. I deleted the old map (I have no memory card) before installing the latest map and it installed with no trouble at all. _________________ Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G |
trevor.dowle Lifetime Member
Posted: Sun Sep 27, 2009 9:58 pm Post subject: |
I've got a 730T and downloaded the latest map a few days ago with no problems, although before the download started I got a message to say that the map would be compressed to 1.8mb due to space limitations! _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Sun Sep 27, 2009 10:04 pm Post subject: |
alan_sh wrote: | To answer the original question - yes they do. I have a 730 and the latest WCE maps.
Alan |
Once all the speech files have been removed I guess ??? _________________ TTGO730
Map WCE 845.2645
Dave. |
keithjeffrey Lifetime Member
Joined: Apr 07, 2006 Posts: 249 Location: Kent , England
Posted: Mon Sep 28, 2009 6:50 am Post subject: |
I've got a 730 and I did'nt have any trouble when I downloaded the last map update.
If I remember correctly I have got about 19mb of memory left available on my 730. _________________ Keith
TomTom GO 730T App 8.392 (1909/091109) , W and CE 2GB v835.2419 |
