Pocket GPS World :: View topic - TomTom GO 4V00.710 - son's loss is my gain
theclaretvillan
PostPosted: Fri Sep 18, 2009 8:41 am    Post subject: TomTom GO 4V00.710 - son's loss is my gain Reply with quote
I know very little about TomTom GPS's but my son gave me his "broken" 710 son time ago and having tried it, it seems to have risen from the dead.
Can anyone help me with information about it please?
The map on it is 650.1046 - how out of date is this likely to be? is updating it costly? It says GB plus major roads of Western Europe, is this of much use in e.g. France?
The SD card is very full 240.2MB/241.4, will I have room to add PGPSW speed camera info (maybe there is something I can delete)?
Can I buy a larger SD card and simply copy the contents of the original on to it?
The useless git (my son) has lost the Home Dock (I'm using a card reader) is there a cheap source of these?
Any other useful info?
Thanks in advance
Ken
PostPosted: Fri Sep 18, 2009 9:17 am    Post subject: Reply with quote
The v650 map is over four years old so you will find certain road layouts such as the lower sections of the M1 and the A1M South of Leeds will be incorrect as well as quite a few other roads. If you want a new map you need to purchase it via TomTom Home running on your PC with the device connected. Prior to doing this make a full backup of the existing card to your PC using Windows Explorer, then update the software on the device to the latest available using Home before finally purchasing a map, the Home application will then download and install the map to your TomTom.
As for use in France it will contain the main roads but not all the smaller local roads, you would need a map such as Western Europe for the device to offer full capability in all of Europe. If you want full Europe consider this when you decide about updates to the map, it will be cheaper in the long run to get the larger map if you need to use it on mainland Europe.
You can fit another SD card to the device, they will support up to 2GB but make sure its a good quality high speed card, I wouldn't purchase a card from E-Bay as there are too many cheap cards that claim to be hight speed that simply won't work in the device. To free up space on the existing card you can remove some files from the voices folder, you only need the UK voices so keep the following files:
data04.chk (UK Tim Voice)
data04.vif
data05.chk
(UK Jane Voice)
data05.vif
All the others can be rmoved.
I would expect the PGPSW speed camera database will fit on the device without removing anything though as the files are quite small in file size. If you are going for the larger Western Europe map then you will need a 2GB card as the map won't fit on the card you currently have.
For a Home Dock E-Bay is probably your best bet, a quick search turned up This which isn't too costly - Mike
theclaretvillan
PostPosted: Fri Sep 18, 2009 10:32 am    Post subject: Reply with quote
data04.vif
data05.chk
(UK Jane Voice)
data05.vif
Thanks Mike
Have updated the speed camera database.
So is 2gb the largest card it can take? - I was going to go for bigger.
Can I just copy the contents of the original card onto the new one?
PostPosted: Fri Sep 18, 2009 10:53 am    Post subject: Reply with quote
I don't think the x10 devices can use cards larger than 2GB and a 2GB card is plenty large enough for a Western Europe map. You can indeed simply copy all the files and folders from the old card to the new card - Mike
PostPosted: Fri Sep 18, 2009 2:28 pm    Post subject: Reply with quote
99% of cards larger than 2GB actually use the SDHC format which the older TomToms cannot handle. There were a couple of 4GB non-HD cards made by Transcend and Topram, but they may no longer be available.
Yes, you should be able to simply copy the contents of the old card to the new one.
(Edited to correct "car/card" typo.)
PostPosted: Fri Sep 18, 2009 2:54 pm    Post subject: Reply with quote
And you may particularly care that it doesn't have the latest London Congestion Zone.
253
PostPosted: Fri Sep 18, 2009 5:25 pm    Post subject: Reply with quote
I have a TT710 with 2Gb card by Veho. Not a well known make but works like a dream.
Full UK WE maps, about 3 years old now I think, not missing much in the way of road layout that I have used in the UK. But haven't used it as far up as Leeds.
Pity it's so bulky otherwise I probably wouldn't have bought the 720 to be honest. Don't need the two of them.
PostPosted: Fri Sep 18, 2009 7:59 pm    Post subject: Reply with quote
Heresy!!!!! That's only half as many as the minimum requirement. Stop it!
253
PostPosted: Fri Sep 18, 2009 10:06 pm    Post subject: Reply with quote
Very Happy
Takes me all the time to manage one, the old 710 is gathering dust under the table last time I saw it.
Which reminds me, better charge it up in case the battery gives up the ghost.
PostPosted: Mon Sep 21, 2009 1:56 pm    Post subject: Reply with quote
Why not sell it to Dennis, I think there's still a tiny unoccupied patch on his windscreen!
theclaretvillan
PostPosted: Mon Sep 21, 2009 2:01 pm    Post subject: Reply with quote
Thx for the help so far. Another question.
Am going to get a map of Western Europe -can I just get any version?
I was going to look on eBay etc - as long as the map is genuine - will it be "locked" - will I have problems loading a second hand one?
PostPosted: Mon Sep 21, 2009 3:40 pm    Post subject: Reply with quote
Have a look at the answers to THIS question.
Basically, a lot of maps on eBay have been found to be dodgy copies.
A genuine map originally supplied on an SD card and still on that same card, should be OK, but then you never know how old it's going to be.....
(Edited to correct link)
PostPosted: Mon Sep 21, 2009 9:03 pm    Post subject: Reply with quote
Eh? That link goes to replacing the battery in a thingy. Question
If you buy maps from anybody other than TomTom, you run a very high risk of buying a pirate copy, which either simply supports the illegal hackers or won't work on your device - maps are linked/locked to individual devices when downloaded, so only SD card purchases are not - in their case, they're locked to the card and cannot be copied and sold on another card. Honestly, you are far safer getting the map from TomTom.com - if it goes wrong, the least you'll have is lost money to some scab.
PostPosted: Tue Sep 22, 2009 3:01 am    Post subject: Reply with quote
Embarassed Oops.. Link now corrected to the right topic.
