Pocket GPS World :: View topic - creating a folder on the memory stick for Nissan Connect
Goto page 1, 2, 3  Next
Brianpowell123
PostPosted: Sun Sep 13, 2009 1:26 pm    Post subject: creating a folder on the memory stick for Nissan Connect Reply with quote
When I attempt to create the folder x:\my pois\mypoiwarnings as soon as I enter the : and the \ it will not accept the characters. I've tried 2 different memory sticks with the same effect
PostPosted: Sun Sep 13, 2009 9:39 pm    Post subject: Reply with quote
Are you trying to follow this instruction?
4. Create a folder on the USB mass storage device (where x = USB mass storage device drive letter) as follows:
x:\my POIs\myPOIWarnings (Note the SPACE between 'my' and 'POIs' in the first folder!)
(From the description HERE)
If so, all it means is to make a folder on the memory stick called "my POIs" and then to make another folder inside that called "myPOIWarnings"
All the colons and slashes are shorthand for that, taken from the old DOS operating system, where drives and folder paths WERE described specifically lie that.
Brianpowell123
PostPosted: Mon Sep 14, 2009 3:52 pm    Post subject: Reply with quote
Thanks for the help Andy, I created the folders as you said and have transfered the file as downloaded but it is not being accepted by the connect, I've been 3 days on this and am running out of ideas
Regards, Brian
Is this file 134kb. I'm wondering if I'm getting all of it. If I try to open it the computer goes berserk flashing on and off so I send the file to a location and click on select all to remove the zip files. I then send it to mypoiwarnings folder and transfer the poiwarnings folder into the pois folder.Have I gone wrong somewhere??????????
I've also scanned the file for viruses.
PostPosted: Mon Sep 14, 2009 8:01 pm    Post subject: Reply with quote
Sorry, I'm afraid I can't be any more help... I understood the folder instruction when I read it, but I haven't a clue about anything specific to the actual Nissan Connect... never even seen one.
PostPosted: Mon Sep 14, 2009 8:13 pm    Post subject: Reply with quote
I did reply to your support ticket on this issue, did you get it?
What files do you now have in your 'myPOIWarnings' folder?
Brianpowell123
PostPosted: Wed Sep 16, 2009 12:42 pm    Post subject: nissan connect download Reply with quote
hello Darren
The folder named ''myPOIWARNINGS'' is advised as a compressed (zipped) folder containing file pgsw-speed-cams-xxxx
I assume that the '' and '' symbols have no significance to the name of the folder
PostPosted: Wed Sep 16, 2009 12:52 pm    Post subject: Reply with quote
I have edited out part the file name you wrote above as it is part of our anti-piracy system.
What 'and' symbols are you referring to? I'm not quite sure what you have here but 'myPOIWarnings' should be a normal folder and it should contain the 'contents' of the zipped database you downloaded from us and not the .zip file itself.
i.e. you download our database which is a compressed (.zip) file and then you extract (uncompress) the contents. It is these resulting files that should be copied to the myPOIWarnings (also note the correct case sensitivity of the folder name).
This is all laid out in the installation guide.
JockTamsonsBairn
PostPosted: Wed Sep 16, 2009 2:14 pm    Post subject: Reply with quote
hello Darren
Darren, I THINK Brianpowell123's post meant
hello Darren
I assume that the Open Double Quotes and Close Double Quotes symbols have no significance to the name of the folder
Jock
PostPosted: Wed Sep 16, 2009 2:17 pm    Post subject: Reply with quote
Ah yes, penny drops, sorry! The quotes are not required in the actual folder name.
Brianpowell123
PostPosted: Thu Sep 17, 2009 10:55 am    Post subject: Reply with quote
Hello again Darren, I think my problem was not realising that the folder titles are case sensitive and had downloaded the file and decompressed it successfully, however, on renaming the folders I neglected to enter the space between the my and POIs. This resulted in a part download as the proceedure did not complete as listed in the 'Connect' booklet.I then pressed the 'Remove my POIs' expecting to start from scratch but nothing happened. I then pressed 'Factory settings' thinking this would enable me to re enter the memory stick. I appear to be back to square one as there is no response from the 'Connect'
PostPosted: Thu Sep 17, 2009 11:25 am    Post subject: Reply with quote
Ok, if you have now got the correct folder structure you should be able to browse to your memory stick and see the first folder:
my POIs with space!
Clicking on that will show you the next folder:
myPOIWarnings
Assuming we're Ok so far, within that folder you should now see a number of files, exclusing any help and licence files which you need to have the following:
pocketgps_uk_pmobile.csv
pocketgps_uk_sc.csv
Do you have them?
Brianpowell123
PostPosted: Thu Sep 17, 2009 1:02 pm    Post subject: Reply with quote
I have six files in all, including the ones you've stated.
PostPosted: Thu Sep 17, 2009 1:04 pm    Post subject: Reply with quote
But do you have the folders as I listed and the files I named above?
Brianpowell123
PostPosted: Thu Sep 17, 2009 1:09 pm    Post subject: Reply with quote
yes I have the folders correctly named, the six files I put into the 'Warnings' folder and then put the 'Warnings folder' into the my POIs folder.
JockTamsonsBairn
PostPosted: Thu Sep 17, 2009 5:43 pm    Post subject: Reply with quote
Can you post a screen dump from Windows Explorer? A picture's worth a thousand words?
From memory there is also a utility, which I've searched for and cant find (x-dir, z-dir??), that allows you to get a fuller listing of a directory structure. Maybe one of the team can remember?
Jock
Page 1 of 3
22.055 (29 May 24)
