M8TJT The Other Tired Old Man
Posted: Sat Aug 08, 2009 7:55 pm Post subject: Continental Speed Cam Speeds |
I have noticed in IGO8, that when you select metric units, the UK speed cam speeds are changed to KPH. A 30 MPH cam is converted to KPH and shows up as 48 KPH. Fine you might say. But what happens to continental cams that are already in KPH? Does it still do the *8/5 conversion and convert a 100 KPH (nominal 62 MPH) cam to 160 KPH  |
linknet Frequent Visitor
Posted: Sun Aug 09, 2009 11:04 am Post subject: Re: Continental Speed Cam Speeds |
M8TJT wrote: | I have noticed in IGO8, that when you select metric units, the UK speed cam speeds are changed to KPH. A 30 MPH cam is converted to KPH and shows up as 48 KPH. Fine you might say. But what happens to continental cams that are already in KPH? Does it still do the *8/5 conversion and convert a 100 KPH (nominal 62 MPH) cam to 160 KPH  |
With metric units selected a continental 100 km/h speed camera remains at 100 km/h. If you then select imperial units it displays as 62 mph.
So it works perfectly for a change.
linknet |
Posted: Sun Aug 09, 2009 5:10 pm Post subject: |
Thanks for the reply Linknet. I suppose that it 'knows' when it's not in UK then (Not a particular challenge for a GPS) and what to do with speed cams. How about that for a correctly thought out algorithm  |
mxmaciek Lifetime Member
Joined: Jun 20, 2007 Posts: 117 Location: UK, Nottingham
Posted: Wed Sep 09, 2009 7:47 am Post subject: |
M8TJT wrote: | Thanks for the reply Linknet. I suppose that it 'knows' when it's not in UK then (Not a particular challenge for a GPS) and what to do with speed cams. How about that for a correctly thought out algorithm  |
I think that this is somewhere in the iGo itself, same like (if you'll enable it) overspeed warning.
One more thing with location-settings for Speed Cams. Even if I had downloaded and set as 'active' speed cams warnings for Germany (this is against the law, don't do it at home, boys and girls ), iGo was quiet. |
