Pocket GPS World :: View topic - No speed camera icons on Garmin Zumo 660
colin_gordon
PostPosted: Wed Aug 26, 2009 8:40 pm    Post subject: No speed camera icons on Garmin Zumo 660 Reply with quote
Hello,
I have just updated the firmware on my Garmin Zumo 660 to version 3.30 and also uploaded the latest speed camera database to my zumo using the latest version of POILoader, and when I view the map I can not see any speed camera icons. I did not have this issue previously.
If I go to Extras - Custom POIs I can see all of the speed cameras, but if I select one and view it on the map there is no icon.
Also if I put the unit into simulation mode and plan a route to the speed camera I get the warning but I do not see the icon.
I have removed and re-installed the camera database multiple times and updated the firmware a couple of times as well but I still can not see the icons :-(
Does anyone have any ideas? or has anyone seen the same problem?
Thanks for your time.
PaulB2005
PostPosted: Wed Aug 26, 2009 9:44 pm    Post subject: Reply with quote
Moved to Garmin PND as this is more a Garmin issue...
GerryC
PostPosted: Thu Aug 27, 2009 9:10 am    Post subject: Reply with quote
How many POI categories have you got loaded? After a certain limit, the icons change to grey or black dots.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
colin_gordon
PostPosted: Thu Aug 27, 2009 11:33 am    Post subject: Reply with quote
I have 31 categories for the speed cameras in the Custom POI section, and I have AA days out loaded as well in a separate extras section.
hunterr1
PostPosted: Mon Aug 31, 2009 1:50 pm    Post subject: Garmin 660: No speed POI Reply with quote
Hi there. I am getting this same probl;em. 3.30v Garmin softwar. latest speeed database. No speed icons etc areappearing even in sim mode?? HELP
PaulB2005
PostPosted: Tue Sep 01, 2009 7:58 am    Post subject: Reply with quote
Have you tried redownloading and reloading the database?
hunterr1
PostPosted: Tue Sep 01, 2009 7:17 pm    Post subject: zumo 660 speed icons Reply with quote
no not yet but am getting a message at startup as unit booting up saying garmin poi locked. however basis sped camera grey box data is coming up on unit on maps. this is my seconf zumo unit. I had a 550 b4. no problems.
colin_gordon
PostPosted: Wed Sep 02, 2009 7:08 pm    Post subject: Reply with quote
I have opened a call with Garmin and they are looking into the problem. As soon as I get some news I will share ...
hunterr1
PostPosted: Wed Sep 02, 2009 9:10 pm    Post subject: garmin zumo 660 problem speed icons Reply with quote
just for completeness. I downloaded uk speed database. renamed it ukpoi. idownloaded euro speed database. renamed it europoi. I downloaded lots of useful poi for food.shopping.transport etc etc. renamed them all under their type withpoi at the end. they all show on the garmin custom pois. it also finds it on the map when chosen. however as stated before no speed icons show and also no other custom poi show on the map. I had before done them individually but again no icons. please be aware I have also tried gerry c speed icons but agin no icons. I used the speed zone database and icons from gerry c. thanks again. wonder if any others r havkng problems.
PaulB2005
PostPosted: Wed Sep 02, 2009 9:30 pm    Post subject: Reply with quote
hunterr1 - Can you try JUST the UK database. As mentioned above the problem usually occurs if you load too many POI categories....
hunterr1
PostPosted: Thu Sep 03, 2009 8:03 am    Post subject: garmin zumo 660 speed icon problem Reply with quote
I think I did this before when testing different things. however I cannot remember if it worked. don't think it did. I will take everything off the unit and try the uk database only. do u know the poi limits for the 660? speed and other types?
PaulB2005
PostPosted: Thu Sep 03, 2009 8:20 am    Post subject: Reply with quote
usually 255 categories.
chastreo
PostPosted: Wed Sep 09, 2009 12:47 pm    Post subject: Problem Fixed Reply with quote
Hi all.
Here is a solution from the Zumo forum. (you ought to join us for all the Zumo 660 info)
Change the Icons to 16bit, using MS Paint, and then they display OK again.
I've just done this on my 660 and the speed PGPSW db is working again.
Hopefully Garmin will release an update soon to fix the problem, but for now get out MS Paint and sort it your self.
Just load each Icon, then click 'Save As'. It will offer to save as a 256 colour Icon, choose 16 colour instead and say yes to the 'Overwrite' request.
colin_gordon
PostPosted: Wed Sep 09, 2009 9:11 pm    Post subject: Reply with quote
I can confirm the above workaround works for me :-)
hunterr1
PostPosted: Wed Sep 09, 2009 9:41 pm    Post subject: No speed camera icons on Garmin Zumo 660 Reply with quote
thanks. i will give it a go.
