Goober556 Occasional Visitor
Posted: Fri Jul 24, 2009 11:28 am Post subject: Navigon update is out |
On the App Store now.
Official updates are:
- Additional languages (UI and voice guidance): Portuguese, Czech, Polish, Turkish, Croatian, Romanian, Slovakian, Greek and Russian
- NAVIGON’s route planning function known from the companies PND line that enables users to plan a route with several destinations
- Radarinfo (not for all countries)
- Additional map view options (now displays street names in 3D view, optional points of interest (POI) dispoay)
- Call POI function (call the number of a point of interest or save it to your contacts)
- POI Filter (allows you to manage the POI’s shown on the map)
- Optimized volume control when using NAVIGON navigation and the integration iPod function of the iPhone at the same time
AshleyHinton Occasional Visitor
Joined: Dec 13, 2004 Posts: 30 Location: Oxfordshire UK
Posted: Fri Jul 24, 2009 4:33 pm Post subject: |
I installed the update this morning and then used it properly to somewhere I hadn't been before.
I've got to say this app is growing on me more and more, its so nice to have a sat-nav app in the iPhone - even with limitations, some of which may be Apple imposed (I'm thinking handling calls within the app)
Before you read the rest - PLEASE backup first - if anything goes wrong its not my fault
For anyone interested in what's inside the Navigon app:
Sync the iPhone to iTunes if you've updated the app within the phone.
On your computer look in your Mobile Applications folder (on the Mac, this is: (your hard disk)/Users/(youruser)/Music/iTunes/Mobile Applications.
Find the NAVIGON.ipa file (may be NAVIGON 1.ipa after the update)
COPY this file somewhere.
Rename the copy from .ipa to .zip.
Un-zip it.
In the un-zipped folder (NAVIGON) you'll find a folder called Payload.
Now on the Mac you can right click (or control-click) and "view package contents" - I'm guessing there is an app for the PC which might let you do the same?
Inside the package is the whole thing, the app, the maps etc.
Of interest is a folder called: "Overmaps" - which contains POM files, POIWARNER.NFS and some other stuff.
I've no idea if this can be made use of, for example with the PocketGPS World speed cameras, or indeed if it would break any kind of EULA because of a "hack"
Even if something was changed - the contents "re-zipped" and then changed back to an .ipa file and the put back on the iPhone - whether it would work I dunno!
Way beyond me - but I thought I'd share the knowledge gained by poking around so far. _________________ TT GO Original / v7 / 1GB SD - Mac's with 10.6 Snow Leopard - iPhone 3G with CoPilot, Navigon & NDrive - Linux PC with Crunchbang. |
Posted: Fri Jul 24, 2009 6:31 pm Post subject: |
It looks like the update has been removed from the app store - mine is still running v1,0,0 Europe Build and no updates offered - Mike |
Posted: Fri Jul 24, 2009 6:59 pm Post subject: |
The speed cams are ok (ish).
You get a voice warning when you get close, it says "Beware, watch your speed". Only the one warning and no audio warning of the speed limit, you have to look at the screen for that.
Seems to do gatso and specs. Traffic light cams are shown on the map, but no audio warning at all. No mobile cams of course.
No indication I can find on where the camera info is from or how often they will be updated. |
Posted: Fri Jul 24, 2009 7:06 pm Post subject: |
mikealder wrote: | It looks like the update has been removed from the app store - mine is still running v1,0,0 Europe Build and no updates offered - Mike |
Doesn't look like they've done the Europe version yet. I've got the UK version. Have updated the thread title. |
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Fri Jul 24, 2009 8:15 pm Post subject: |
Updated mine this morning , seems a lot better and more road signs ect in 3D mode have not done a run with it as yet otherwise a good program ,just waiting for Sygic now for UK maps should be shortly. _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
TELREA Lifetime Member
Posted: Fri Jul 24, 2009 9:15 pm Post subject: |
Wonder if this update will help sort out the constant gps dropouts i have had day 1 |
3GGG Frequent Visitor
Joined: 26/09/2002 13:55:07 Posts: 269 Location: United Kingdom
Posted: Sun Jul 26, 2009 1:55 pm Post subject: |
Quote: | Optimized volume control when using NAVIGON navigation and the integration iPod function of the iPhone at the same time
What does this do? - can you set volume of navigation voice at a different level to iPod music? - If so that would be great. |
Posted: Sun Jul 26, 2009 2:43 pm Post subject: |
3GGG wrote: | Quote: | Optimized volume control when using NAVIGON navigation and the integration iPod function of the iPhone at the same time
I think the iPod auto-quiets when the navigation voice kicks in and then goes back to normal. Would be good if someone can confirm how well this works?
georgia2005 Occasional Visitor
Joined: Mar 01, 2006 Posts: 2 Location: Northmptonshire
Posted: Sun Jul 26, 2009 4:59 pm Post subject: |
The ipod volume decreases by bout 75% when the navigation voice comes in then returns to normal. Also in the options menu you can set the volume for the navigation. As I change my car a lot have been using a venturi mini playing music, using navigation and the phone with no problems. I have yet to try out some of the other new features. Shame about the postcode not being sorted out yet. |
Posted: Sun Jul 26, 2009 9:33 pm Post subject: |
Navigon update for those of us running the Europe mapping is now available, bear in mind this is a large download as it has to download and install everything from scratch - how bl**dy stupid, a small 30MB update needs a 1,61GB download, it took over an hour even on my high speed internet connection.
Apple really do need to consider how downloads are supplied for the navigation applications as the map data should be kept seperate where possible, huge downloads such as this for a simple update are not very user friendly as they take ages! - iTunes and app store might have been OK for the smaller applications we have all been using, but things have now moved up a gear, costly applications with free updates are a great thing, but consuming over an hour for a simple application update ain't too smart.
Will be giving it a try in the morning though, although the update doesn't offer too much of interest to me by the looks of things - Mike |
Posted: Sun Jul 26, 2009 9:40 pm Post subject: |
Apple need to come up with a way of patching apps like this on the iTunes Store as this "download it all again" is hugely inefficient for everyone. |
classy56 Frequent Visitor
Posted: Mon Jul 27, 2009 12:56 am Post subject: |
mikealder wrote: | but consuming over an hour for a simple application update ain't too smart.
Do you dowwnload via Itunes on your computer or Iphone? _________________ Tomtom Go730T
App 8.300
Map v815.2003
To old to die young. |
Posted: Mon Jul 27, 2009 7:50 am Post subject: |
Anything over 10MB has to be downloaded via your computers internet connection WiFi access point directly to the phone, you cannot use the 3G of the phone for updates unless they are less than 10MB - Mike |
Posted: Mon Jul 27, 2009 10:43 am Post subject: |
mikealder wrote: | Anything over 10MB has to be downloaded via your computers internet connection WiFi access point directly to the phone, you cannot use the 3G of the phone for updates unless they are less than 10MB - Mike |
I know that Mike, but I asked do you use Itunes on your computer or on your Iphone, in other words do you download to your computer first, then sync with your Iphone, or do you do it all directly via the Iphone app? _________________ Tomtom Go730T
App 8.300
Map v815.2003
