Pocket GPS World :: View topic - MS AutoRoute and Garmin
FXRStuarty
PostPosted: Thu Jul 23, 2009 7:23 pm    Post subject: MS AutoRoute and Garmin Reply with quote
Can I download routes from MS Autoroute to my 760T?
TIA Smile
gatorguy6996
PostPosted: Thu Jul 23, 2009 8:47 pm    Post subject: Reply with quote
Yes, but IIRC you will need a conversion program like GPSBabel to put it in the proper format.
Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr.
Oldboy
PostPosted: Thu Jul 23, 2009 9:22 pm    Post subject: Reply with quote
POIConverter, from out own Oldie can read the AuitoRoute .AXE files, and export them in several formats.
gatorguy6996
PostPosted: Thu Jul 23, 2009 11:31 pm    Post subject: Reply with quote
Then that's even better! Smile
FXRStuarty
PostPosted: Sun Jul 26, 2009 10:12 am    Post subject: Reply with quote
This looks like what I need so I have downloaded it to my laptop.
Have had a wee look at it and tried to load a saved journey constructed using Autoroute.
When I try to load the route in to POI Converter the file does not show in windows explorer. I assume this is due to the file extension. POI C looks for .csv files and my saved file is a .axe and the only other option is .axt
Where am I going wrong?
Grateful for further guidance.
TIA Smile
Oldboy
PostPosted: Sun Jul 26, 2009 11:05 am    Post subject: Reply with quote
Select as Filetype Microsoft Maps. Wink
FXRStuarty
PostPosted: Sun Jul 26, 2009 11:35 am    Post subject: Reply with quote
Thanks.
I did as you said and, after inserting the push pins, I now have a list of 11 journey points shown as Push Pins.
I have a Garmin 760 and so I saved this as a Garmin file. Is this correct? After connecting my Garmin to my laptop how do I get this in to my Garmin? Where should the journey be saved? On the SD card?
Sorry for the dumb questions but this is all new to me. Embarassed
Oldboy
PostPosted: Sun Jul 26, 2009 5:09 pm    Post subject: Reply with quote
I'm afraid we've reached the limit of my knowledge now (in respect of Garmins), so someone with more specific know-how will need to lead you further.
Meter_Man
PostPosted: Mon Jul 27, 2009 5:03 pm    Post subject: Loading your pushpins Reply with quote
The best way to do this is using mapsource. You import them into mapsource from the list that you need to save as a Garmin Database file (.gdb) then select them all, click edit and make a route from selected items.
You then transfer the route to your garmin from mapsource. Now, go to Tools, My Data on the Garmin, Import Route from file and Bingo!
FXRStuarty
PostPosted: Mon Jul 27, 2009 5:57 pm    Post subject: Re: Loading your pushpins Reply with quote
What is Mapsource?
Have had a look at Garmin website and the download is there. However it will only install if a previous version is found on the PC taking the download.
dales
PostPosted: Tue Jul 28, 2009 11:32 am    Post subject: Reply with quote
If I recall correctly, posts elsewhere in this forum have said that a copy of Mapsource is included in the Garmin Training Database package, which is here.
Dales.
FXRStuarty
PostPosted: Wed Jul 29, 2009 5:11 pm    Post subject: Reply with quote
Dales.
Cant download the software at the link. It again says "Previous MapSource Not Found. Download will terminate"
Help! Sad
FXRStuarty
PostPosted: Wed Jul 29, 2009 7:29 pm    Post subject: Reply with quote
Come on peeps, someone must be able to assist me to get the MS Autoroute map to my Garmin? Smile
Meter_Man
PostPosted: Wed Jul 29, 2009 7:53 pm    Post subject: POIs to 760 Reply with quote
Apologies
Have you purchased a map upgrade?
If you haven't, apparently you can't have Mapsource on your PC.
If you PM me your postal address, I'll gladly send you a CD with mapSource on it but I'm unsure if it will work until you have a ma pon your PC
FXRStuarty
PostPosted: Tue Aug 18, 2009 3:20 pm    Post subject: Re: POIs to 760 Reply with quote
Meter_Man wrote:
Apologies
Been real busy of late and want to thank you for your offer. I ended up plotting the route on Garmin unit rather than downloading from MS Autoroute.
It has prompted a question though, how can I use the Garmin unit to its full potential if I cant get access to all the tools e.g. Mapsource?
Confused
22.054 (22 May 24)
