Pocket GPS World :: View topic - Satmap turning off when locked and freezing
John65
PostPosted: Fri Jul 24, 2009 8:24 am    Post subject: Satmap turning off when locked and freezing Reply with quote
The last two times I have used my satmap it has turned itself off even though locked.
I put it in bag with a good signal. When I get it out later on the unit is off. There has also been freezing.
Any ideas please?
Ta,
John
4ndynorfolk
PostPosted: Fri Jul 24, 2009 10:46 am    Post subject: Reply with quote
Are you sure that you have not set the device to turn off after a certain time?
I ask because after the last upgrade I inadvertently set the device to turn off instead of just the screen. Both are set from the same settings page.
Failing that I suggest you ring Satmap.
John65
PostPosted: Fri Jul 24, 2009 10:58 am    Post subject: Reply with quote
No, I thought that but power for the unit is always on. I'll give them a ring.
4ndynorfolk
PostPosted: Fri Jul 24, 2009 11:53 am    Post subject: Reply with quote
A loose or dirty battery connection might also cause this.
terry8
PostPosted: Fri Jul 24, 2009 6:01 pm    Post subject: Reply with quote
I suppose there must be a reason for unit to turn off after a certain period of
time, though I must admit I cannot think of it. This has caused me grief in the past by mistakenly setting the unit to power down after a short period of time instead of setting screen to switching off. Now you have to wait for it to lock on again. Maybe if they did not have the two settings in such close proximity it would help "numpties" like me
22.055 (29 May 24)
