dontcare1970 Occasional Visitor
Posted: Wed Jul 22, 2009 4:44 pm Post subject: no search option streetpilot i3 |
Hi, HELP, I have just updated my maps on my streetpilot i3 with imgps2, and it has loaded fine but there is no search option to look for new addresses, any help will be wonderful.
Thanks Nick. |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Wed Jul 22, 2009 5:52 pm Post subject: |
What is imgps2. I have several i3's and have never seen that update. |
Posted: Wed Jul 22, 2009 7:51 pm Post subject: |
IMG2GPS is a Windows GUI for the SendMap / Sendmap20 DOS application by gps_mapper.
It will transfer any Map file (.img format) to your Garmin GPS.
It will work for Garmin maps as well as home-made maps. |
Posted: Thu Jul 23, 2009 6:06 am Post subject: |
What map did you load? |
Posted: Thu Jul 23, 2009 3:13 pm Post subject: Re: no search option streetpilot i3 |
dontcare1970 wrote: | Hi, HELP, I have just updated my maps on my streetpilot i3 with imgps2, and it has loaded fine but there is no search option to look for new addresses, any help will be wonderful.
Thanks Nick. |
Can you select the Garmin map in the i3's menus, or have you only loaded a none Garmin map.
I would think that a none Garmin map would not contain the address data needed to use the search function. Not sure what would happen if you selected the Garmin map in the i3's menu, then searched address to navigate to, then switched maps in the i3's menu
What happens if you use this program to just load the original Garmin map, does the search work then. If not it would seem that the program cannot handle the address data or strips it away when loading it. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Thu Jul 23, 2009 3:27 pm Post subject: |
pretty certain that SOME of the garmin maps don't do routing - eg the Metro Guide i'm sure did not have routing, just actual maps. maybe it was one of those maps?
MaFt |
Posted: Thu Jul 23, 2009 3:35 pm Post subject: |
You could be right MaFt
When you use Garmin's MapSource to load a road map, it can take ages to compile the index/address data before it transfers it to the device. |
