Pocket GPS World :: View topic - Garmin nüvi 300 - Won't Turn On
Spuddyboy
PostPosted: Sat Jul 18, 2009 1:17 pm    Post subject: Garmin nüvi 300 - Won't Turn On Reply with quote
Hi Guys,
I have a Garmin nüvi 300 and I can't get it to turn on at all. I've tried the in-car charger and a mini-usb cable from my computer.
Is this a common problem on these devices? And if so is there a fix?
Any help would be greatly appreciated.
Thanks in advance.
Ben
PhilHornby
PostPosted: Sun Jul 19, 2009 4:56 pm    Post subject: Reply with quote
How was it behaving, when it was last powered on successfully?
When you try to power it on now, do you get the confirmation 'bleep'?
Spuddyboy
PostPosted: Mon Jul 20, 2009 9:42 am    Post subject: Reply with quote
It was behaving fine before, nothing out of the ordinary.
When I try to turn it on I don't get anything at all. No beeps, no lights, nothing.
Thanks for the response
PhilHornby
PostPosted: Mon Jul 20, 2009 11:52 am    Post subject: Reply with quote
The ON/OFF switch is a weak point, but wouldn't give the symptoms you're expericencing.
Has you tried both USB ports (ie the one on the cradle, as well as the one on the unit itself)?
Other than that, the only thing I can think of that might bring it back to life, is disconnecting and reconnecting the battery.
There are some dismantling instructions here and here (the second set are mine, but are more appropriate for the 310/360/370 - the 300/350 has a smaller circuit board and you can probably get at the battery connector without removing the PCB.)
Spuddyboy
PostPosted: Mon Jul 20, 2009 4:10 pm    Post subject: Reply with quote
Yeah I've tried both USB ports.
I have just ordered some Torx screwdrivers, would you suggest ordering a replacement battery as well?
Ben
P.s.. I've just noticed that you are just up the road from me really. I'm in Macclesfield
PhilHornby
PostPosted: Tue Jul 21, 2009 10:39 pm    Post subject: Reply with quote
Ideally, a spot of diagnosis with a voltmeter would be the first step, before buying a new battery...
borjo
PostPosted: Wed Jul 29, 2009 11:57 am    Post subject: dead 310 Reply with quote
I have a 310 and it died on me same symptoms as as above so i dismantled and tested the battery voltage it reads 3.76v . Is there any thing else I can try or should throw it away and buy a new one? It`s a shame becuse I liked my 310 .
Spuddyboy
PostPosted: Thu Jul 30, 2009 8:52 am    Post subject: Reply with quote
I've taken it apart and it seems like a chip has blown.
The chip is located above the screw hole on the mobo.
borjo
PostPosted: Fri Jul 31, 2009 10:28 am    Post subject: dead 310 Reply with quote
Ditto exactly the same I guess it`s a weak point although I have to admit I was using a universal phone charger at the time which I have used before without any problems.I`v learnt my lesson now always use the dedicated charger .What to replace it whit tried the 765 but found it to be unstable and sent it back.[/list][/b][/quote]
22.055 (29 May 24)
