Spuddyboy Occasional Visitor
Posted: Sat Jul 18, 2009 1:17 pm Post subject: Garmin nüvi 300 - Won't Turn On |
Hi Guys,
I have a Garmin nüvi 300 and I can't get it to turn on at all. I've tried the in-car charger and a mini-usb cable from my computer.
Is this a common problem on these devices? And if so is there a fix?
Any help would be greatly appreciated.
Thanks in advance.
Ben |
PhilHornby Frequent Visitor
![](http://phil.hornby.me.uk/images/FaceBookVVsmall.jpg)
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Sun Jul 19, 2009 4:56 pm Post subject: |
How was it behaving, when it was last powered on successfully?
When you try to power it on now, do you get the confirmation 'bleep'? |
Posted: Mon Jul 20, 2009 9:42 am Post subject: |
It was behaving fine before, nothing out of the ordinary.
When I try to turn it on I don't get anything at all. No beeps, no lights, nothing.
Thanks for the response |
Posted: Mon Jul 20, 2009 11:52 am Post subject: |
The ON/OFF switch is a weak point, but wouldn't give the symptoms you're expericencing.
Has you tried both USB ports (ie the one on the cradle, as well as the one on the unit itself)?
Other than that, the only thing I can think of that might bring it back to life, is disconnecting and reconnecting the battery.
There are some dismantling instructions here and here (the second set are mine, but are more appropriate for the 310/360/370 - the 300/350 has a smaller circuit board and you can probably get at the battery connector without removing the PCB.) |
Posted: Mon Jul 20, 2009 4:10 pm Post subject: |
Yeah I've tried both USB ports.
I have just ordered some Torx screwdrivers, would you suggest ordering a replacement battery as well?
Ben
P.s.. I've just noticed that you are just up the road from me really. I'm in Macclesfield |
Posted: Tue Jul 21, 2009 10:39 pm Post subject: |
Spuddyboy wrote: | would you suggest ordering a replacement battery as well? |
Ideally, a spot of diagnosis with a voltmeter would be the first step, before buying a new battery... |
borjo Occasional Visitor
Posted: Wed Jul 29, 2009 11:57 am Post subject: dead 310 |
I have a 310 and it died on me same symptoms as as above so i dismantled and tested the battery voltage it reads 3.76v . Is there any thing else I can try or should throw it away and buy a new one? It`s a shame becuse I liked my 310 . |
Posted: Thu Jul 30, 2009 8:52 am Post subject: |
I've taken it apart and it seems like a chip has blown.
The chip is located above the screw hole on the mobo. |
Posted: Fri Jul 31, 2009 10:28 am Post subject: dead 310 |
Spuddyboy wrote: | I've taken it apart and it seems like a chip has blown.
Ditto exactly the same I guess it`s a weak point although I have to admit I was using a universal phone charger at the time which I have used before without any problems.I`v learnt my lesson now always use the dedicated charger .What to replace it whit tried the 765 but found it to be unstable and sent it back.[/list][/b][/quote] |
