loro Lifetime Member
Posted: Mon Jun 15, 2009 9:38 am Post subject: QuickGPSFix Download |
i've noticed that when i connect my Go 530 to tomtom home i am not being offered any QuickGPSFix downloads? when i connect with a TT one i get them, is this QuickGPSFix only for the TT one ? or have a got a problem with the TT Go 530 any help would be appreciated |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Mon Jun 15, 2009 11:31 am Post subject: |
If QuickGPSFix download is a must for you (I haven't downloaded it since February 2008 when some of us concluded it was doing nasty things to our devices), there has been some discussion recently - do a Search for it. If I recall correctly, it is to do with TomTom Navcore updates being incomplete in some respects and you may have ended up with a file or three missing.
In the meantime, don't lose sleep over it - if you use your 530 more than once a week and have "Startup Preferences" set to "Continue where I left off", you shouldn't have any trouble without it. _________________ Dennis
Two of them are obesiting!! |
dhn Frequent Visitor
Posted: Mon Jun 15, 2009 11:48 am Post subject: |
Dennis .... a question for you.
'Continue where I left off' is the setting I use for my 720 here in NA but, in a few weeks, my wife takes the unit to Britain. I realize that it will take longer for the unit to 'grab' a gps signal initially than it does when I turn it on here but wouldn't having the 'continue....' setting active make a satellite signal capture even longer initially?
(I have visions of her at Manchester Airport swearing mightely at the unit as it waits ... and waits ..... for a signal on that side of the pond. ) _________________ David |
Posted: Mon Jun 15, 2009 11:57 am Post subject: |
I always thought the "Continue where i left off" just meant it returned you to whatever screen you where on when you switched off and had nothing to do with GPS Fix or location.
For example if i go into the Map Corrections page and then switch off, when i switch on with "Continue where i left off" selected after the splash screen it takes me back to the Map Corrections screen. The other options Ask for a Destination, Show the Main Menu and Start Slide show act according to their description.
I have i missed something here? |
Posted: Mon Jun 15, 2009 12:24 pm Post subject: |
Appears you are correct, Paul. From the manual:
Continue where I left off - your GO starts and shows the last screen that
was shown when you turned off the device.
Guess I should read it more often
Thanks. _________________ David |
Darren Frequent Visitor
Posted: Mon Jun 15, 2009 1:14 pm Post subject: |
Is your wife hiring a car at Manchester Airport? If so, best advice is to install GPS, switch on and then wait for a signal if in the open or move to the first place she can safely stop and allow it time to re-acquire.
Driving off and hoping it will catch up is always a mistake, I know having tried it myself too many times! The hard part is finding somewhere to stop. Most time you're under cover when you pick up the car and airports aren't the easiest places to pull up in! _________________ Darren Griffin |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Mon Jun 15, 2009 1:28 pm Post subject: Re: QuickGPSFix Download |
loro wrote: | i've noticed that when i connect my Go 530 to tomtom home i am not being offered any QuickGPSFix downloads? when i connect with a TT one i get them, is this QuickGPSFix only for the TT one ? or have a got a problem with the TT Go 530 any help would be appreciated |
If you have every backed up your 530 with TT HOME then when connected to TT HOME just click on the Add Traffic, Voices etc tab, then click to the screen with the Items on my computer, look down the list, then you should see QuickGPSfix Data, click to add to your 530. The next time you update it should now offer the latest file.
OR
If you have ever backed up via Explorer, have a look at the back up and find the folder ephem. There should be 3 files in it, just copy the 3 files to your 530 and again next time you connect to TT HOME and update it should offer you the QuickGPSfix Data. |
Posted: Mon Jun 15, 2009 1:30 pm Post subject: |
DennisN wrote: | If QuickGPSFix download is a must for you (I haven't downloaded it since February 2008 when some of us concluded it was doing nasty things to our devices), there has been some discussion recently - do a Search for it. If I recall correctly, it is to do with TomTom Navcore updates being incomplete in some respects and you may have ended up with a file or three missing.
In the meantime, don't lose sleep over it - if you use your 530 more than once a week and have "Startup Preferences" set to "Continue where I left off", you shouldn't have any trouble without it. |
thanks for the replies all
but before i attempt to correct this on my Go, can you please enlighten me on what the nasty things are |
Posted: Mon Jun 15, 2009 2:00 pm Post subject: |
To Darren:
Thanks. Have advised her to expect a delay and to try to do exactly that, get in an open place, have a ciggy, and let it acquire a signal.
p.s. Going to pm you about a severe problem I'm seeing in another forum. _________________ David |
Posted: Mon Jun 15, 2009 2:04 pm Post subject: |
ah right DennisN have done search and found some posts will read and digest later thanks
Pocketgps..........thanks found folder on a backup i had done on my old TT one |
Posted: Mon Jun 15, 2009 2:19 pm Post subject: |
dhn wrote: | Appears you are correct, Paul. From the manual:
Thanks. |
Well there you go. Maybe I should change my signature to NEVER RsTFM. That might explain why my GO700 didn't find itself lost today - I had switched it off and hidden it in my secret hidey hole in the van whilst I was out shopping, forgot to get it out and plug it in. Drove home and when I went out again, realised I hadn't given it chance to Continue where I left off. Switched on and thought I'd have to wait ages (especially as the 700 is Sirf 2 not 3). But I didn't, it found satellites as quickly as usual.
It's all too much for me, I don't understand this new modern technology stuff. Back in the olden days, I'd go out there, start up and say "Where to?" and the (thank God Ex) wife would tell me (and add "Get on with it, that's petrol you're using sitting here with the engine running!"). _________________ Dennis
Posted: Mon Jun 15, 2009 2:32 pm Post subject: |
loro wrote: | but before i attempt to correct this on my Go, can you please enlighten me on what the nasty things are |
We went through a period when our devices were falling off the roads, or starting up a few hundred yards away from our actual location (say halfway between here and the next street). I did several miles southbound a couple of hundred yards or so to the east, off the M6. Everybody flopped around trying to guess the reason and some of us decided it was the QuickGPSFix and stopped downloading it. I haven't had the problem since - doesn't mean that WAS the problem, TomTom move in mysterious ways. Same sort of unproven gut feeling as we have about the nasties caused by MapShare (except we think it's proven with MapShare!). They may have had a "Bring your managing director's favourite daughter to work" day and let her have a play with QuickGPSFix. Who knows? I don't download it and have not noticed any problem acquiring and holding satellites. _________________ Dennis
Posted: Mon Jun 15, 2009 2:47 pm Post subject: |
Thanks DennisN
i totally agree with you on the mapshare issue, i don't use it myself either, thanks for your input, now to decide whether to put these files on my Go ? or leave them off decisions, decisions |
AndyVaughan Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_matrix_014.jpg)
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Mon Jun 15, 2009 7:18 pm Post subject: |
I always used quickgpsfix on the 920 and didn't have problems.
On the borrowed 930 it has never been used and it takes all of about 2 seconds longer to get a satellite lock.
Make your own mind up, but it doesn't seem to do much for me. |
Posted: Mon Jun 15, 2009 7:55 pm Post subject: |
AndyVaughan wrote: | On the borrowed 930 it has never been used and it takes all of about 2 seconds longer to get a satellite lock. |
You've busted the damn thing already! And it's not even yours.
I was hoping to have a borrow of that myself when I get back off holiday and you've got your all singing, all dancing, 920 back from TT, so that I can send them mine. ![Evil or Very Mad](modules/Forums/images/smiles/icon_evil.gif) _________________ Dennis
