Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 25, 26, 27 ... 33, 34, 35  Next
linknet
PostPosted: Tue Apr 28, 2009 8:05 am    Post subject: Re: Hungarian Language File for PNA for iGO8 Ultra Skin v6.0 Reply with quote
kincseslevi wrote:
Hungarian Language File for PNA for iGO8 Ultra Skin v6.0.21:
Thanks for that, I've added it to the website download page.
linknet
rider67
PostPosted: Thu May 07, 2009 1:03 pm    Post subject: Reply with quote
Firstly, thanks for your skins.
I just installed your last skin, and i have a little request : we can no longer disable camera warning by type of speedcam ( mobile, fixed .. ). There are so many mobile speedcams that it is very unpleasant to activate warnings on a long route. In the lasts versions could do this.
Nathan
linknet
PostPosted: Thu May 07, 2009 2:06 pm    Post subject: Reply with quote
Unfortunately this involves installing the complete speedcam handling module which I have decided for a number of reasons not to install.
I'm afraid the only solution is to remove the mobile speed cameras from the speedcam databases, which is what I always do anyway.
linknet
LolitaDamore
PostPosted: Thu May 07, 2009 7:27 pm    Post subject: Reply with quote
Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
DefenderBLACK
PostPosted: Thu May 28, 2009 11:40 pm    Post subject: FFUI Error? Reply with quote
have installed latest skin to lastest map version but when loading get a FFUi error - unkonown object indentifier indentifier=[vmapmodebocl] script [unamed] command 0
then
ffui error:unknown
object indentifier indentifier=[vgetupdates] script "st_start_init" command 45
running on ipaq 3970 with 1gb card and 63mb mem
same prob when running old ver 5 as well?
HELLPPPPPP
Paul
PostPosted: Fri May 29, 2009 8:12 am    Post subject: Reply with quote
What version of IGO are you using? I believe linknet's ultra 5 and 6 skins only work with Ver 8.3.xxx
linknet
PostPosted: Fri May 29, 2009 8:13 am    Post subject: Reply with quote
deleted
DefenderBLACK
PostPosted: Fri May 29, 2009 8:57 pm    Post subject: Reply with quote
latest i think its 8.3.2.64029 nov 7 2008
linknet
PostPosted: Sat May 30, 2009 8:58 am    Post subject: Reply with quote
If that's the case then the FFUI errors you are getting with the Ultra Skin 6.021 are the result of a data.zip file which doesn't match the version of iGO8 that you are using.
You need the correct data.zip file for the 8.3.2.64029 version of iGO8.
linknet
DefenderBLACK
PostPosted: Sat May 30, 2009 9:53 pm    Post subject: Reply with quote
latest i can found is shown on the website. ?
linknet
PostPosted: Sat May 30, 2009 11:09 pm    Post subject: Reply with quote
Sorry but I don't understand. Confused
As I said before, you need the correct data.zip file for the 8.3.2.64029 version of iGO8. This file is included with the iGO8 software and is not part of the skin.
linknet
DefenderBLACK
PostPosted: Sun May 31, 2009 11:11 am    Post subject: Reply with quote
how can i tell? the date of creation shows as ‎25 ‎September ‎2008, ‏‎13:54:16
But other than that im not sure how to find out other than it doents work - can i download from somewhere a correct one?
Thanks for your help.
Paul
linknet
PostPosted: Sun May 31, 2009 11:42 am    Post subject: Reply with quote
Paul
The data.zip file for iGO 8.3.2.64029 is dated 7 November 2008 14:41:46
You need to visit https://www.naviextras.com/shop/portal and update your version. This is the only legal way to do this.
linknet
webpatrick
PostPosted: Tue Jun 02, 2009 1:41 pm    Post subject: Reply with quote
I modified the 6.0.21 version a bit:
- nicer background for speed indication (including dropshadow)
- some enhanced speed and camara backgrounds
- colored battery indicator (green=full, red=empty and some colors in between)
http://ressiv.com/iGO8_Ultra_6.0.21_mod.zip
webpatrick
PostPosted: Tue Jun 02, 2009 1:43 pm    Post subject: Reply with quote
webpatrick wrote:
I modified the 6.0.21 (240x320) version a bit:
I thought let's share it.
Page 26 of 35
