linknet Frequent Visitor
Posted: Tue Apr 28, 2009 8:05 am Post subject: Re: Hungarian Language File for PNA for iGO8 Ultra Skin v6.0 |
kincseslevi wrote: | Hungarian Language File for PNA for iGO8 Ultra Skin v6.0.21: |
Thanks for that, I've added it to the website download page.
linknet |
rider67 Occasional Visitor
Posted: Thu May 07, 2009 1:03 pm Post subject: |
Firstly, thanks for your skins.
I just installed your last skin, and i have a little request : we can no longer disable camera warning by type of speedcam ( mobile, fixed .. ). There are so many mobile speedcams that it is very unpleasant to activate warnings on a long route. In the lasts versions could do this.
Nathan |
Posted: Thu May 07, 2009 2:06 pm Post subject: |
rider67 wrote: | I just installed your last skin, and i have a little request : we can no longer disable camera warning by type of speedcam ( mobile, fixed .. ). There are so many mobile speedcams that it is very unpleasant to activate warnings on a long route. In the lasts versions could do this. |
Unfortunately this involves installing the complete speedcam handling module which I have decided for a number of reasons not to install.
I'm afraid the only solution is to remove the mobile speed cameras from the speedcam databases, which is what I always do anyway.
linknet |
LolitaDamore Occasional Visitor
Posted: Thu May 07, 2009 7:27 pm Post subject: |
DefenderBLACK Lifetime Member
Joined: 23/06/2003 17:45:35 Posts: 103 Location: United Kingdom
Posted: Thu May 28, 2009 11:40 pm Post subject: FFUI Error? |
have installed latest skin to lastest map version but when loading get a FFUi error - unkonown object indentifier indentifier=[vmapmodebocl] script [unamed] command 0
then
ffui error:unknown
object indentifier indentifier=[vgetupdates] script "st_start_init" command 45
running on ipaq 3970 with 1gb card and 63mb mem
same prob when running old ver 5 as well?
HELLPPPPPP
Paul |
M8TJT The Other Tired Old Man
Posted: Fri May 29, 2009 8:12 am Post subject: |
What version of IGO are you using? I believe linknet's ultra 5 and 6 skins only work with Ver 8.3.xxx |
Posted: Fri May 29, 2009 8:13 am Post subject: |
deleted |
Posted: Fri May 29, 2009 8:57 pm Post subject: |
latest i think its 8.3.2.64029 nov 7 2008 |
Posted: Sat May 30, 2009 8:58 am Post subject: |
DefenderBLACK wrote: | latest i think its 8.3.2.64029 nov 7 2008 |
If that's the case then the FFUI errors you are getting with the Ultra Skin 6.021 are the result of a data.zip file which doesn't match the version of iGO8 that you are using.
You need the correct data.zip file for the 8.3.2.64029 version of iGO8.
linknet |
Posted: Sat May 30, 2009 9:53 pm Post subject: |
latest i can found is shown on the website. ? |
Posted: Sat May 30, 2009 11:09 pm Post subject: |
DefenderBLACK wrote: | latest i can found is shown on the website. ? |
Sorry but I don't understand.
As I said before, you need the correct data.zip file for the 8.3.2.64029 version of iGO8. This file is included with the iGO8 software and is not part of the skin.
linknet |
Posted: Sun May 31, 2009 11:11 am Post subject: |
how can i tell? the date of creation shows as 25 September 2008, 13:54:16
But other than that im not sure how to find out other than it doents work - can i download from somewhere a correct one?
Thanks for your help.
Paul |
Posted: Sun May 31, 2009 11:42 am Post subject: |
DefenderBLACK wrote: | how can i tell? the date of creation shows as 25 September 2008, 13:54:16
Paul |
The data.zip file for iGO 8.3.2.64029 is dated 7 November 2008 14:41:46
You need to visit https://www.naviextras.com/shop/portal and update your version. This is the only legal way to do this.
linknet |
webpatrick Occasional Visitor
Posted: Tue Jun 02, 2009 1:41 pm Post subject: |
I modified the 6.0.21 version a bit:
- nicer background for speed indication (including dropshadow)
- some enhanced speed and camara backgrounds
- colored battery indicator (green=full, red=empty and some colors in between)
http://ressiv.com/iGO8_Ultra_6.0.21_mod.zip
Posted: Tue Jun 02, 2009 1:43 pm Post subject: |
webpatrick wrote: | I modified the 6.0.21 (240x320) version a bit:
I thought let's share it. |
