Pocket GPS World :: View topic - Submitting POI locations
adamwolfe
PostPosted: Sun May 10, 2009 10:42 am    Post subject: Submitting POI locations Reply with quote
Hi PGPS,
When submitting locations on the web page there seems to be a problem with the search element. If there are more than one possibility for a given town, village etc a list appears but when clicking on the correct one the web page defaults back to the home page. Try finding "Ceres" and you are given a list with "Ceres - Cupar etc" on the list. Click on it and you will see what I mean. This has also happened with other locations as well.
Just thought I'd let you know.
Adam
rayle
PostPosted: Sun May 10, 2009 11:52 am    Post subject: Reply with quote
Have just tried that on my Laptop, Ceres shows as undefined, as doe`s Ceres Cupra.
Ceres, Fife shows the correct location.
Could be a glitch with Tele Atlas as Google Earth shows Ceres in Fife, also a number of Ceres around the World.
Strange.
Garmin Nuvi 2589, IPad2, RAC 05'
PostPosted: Sun May 10, 2009 9:41 pm    Post subject: Reply with quote
adamwolfe wrote:
Hi PGPS,
Yes, where/how are you getting that list of place options, Adam?
If I put "Ceres" in the "find a location" box on the map page HERE, all that happens is the single word "Undefined" appears just above the map itself.
I'm using Firefox 3 browser.
adamwolfe
PostPosted: Mon May 11, 2009 8:00 am    Post subject: Reply with quote
The list below appears under the search box (after typing "Ceres" into the search box) between the box and the top edge of the map. I couldn't find a way of inserting a screen dump into this reply so the list has been copied and pasted in. I'm using XP SP3 with IE8. All of the options are hyper linked as one would expect and when clicking on the Cupar option I am taken back to the PGPS home page. I have tried this many times all with the same result.
Did you mean:
Ceres, Bemmel 6681 Lingewaard, GLD, The Netherlands)
Ceres, Rosario, Santa Fe, Argentina)
Ceres, Captain Boiso Lanza, Uruguay)
Ceres, Katwijk 2221 Katwijk, ZH, The Netherlands)
Ceres, Lima, Lima, Peru)
Ceres, Ulrum 9971 De Marne, GR, The Netherlands)
Ceres, Cupar, Fife KY15, UK)
Ceres, Stanislaus, CA, USA)
Ceres, Broadmead Rd, Woodford Green, Greater London IG8, UK)
Ceres, Veldhoven 5505 Veldhoven, NB, The Netherlands))
Hope that throws some light on this.
Regards
Adam
adamwolfe
PostPosted: Mon May 11, 2009 8:25 am    Post subject: Reply with quote
I have sent an email containing the screen dump to the webmaster address. Hope that helps.
Adam
rayle
PostPosted: Mon May 11, 2009 11:03 am    Post subject: Reply with quote
I am also using Firefox and all appears as it should be.
I have just tried Ceres Find location with IE7 and recieved the same results as Adam, multiple results for mostly in the US.
So it must be something to do with IE7
PostPosted: Mon May 11, 2009 11:42 am    Post subject: Reply with quote
we are aware of the issue. it's an IE / google local issue.
google regularly change their code and as we use a 'hack' of this code if google change it then it no longer works...
the best thing to do is to be more specific in the search terms eg instead of just 'Ceres' put 'Ceres, Katwijk'
PostPosted: Mon May 11, 2009 2:44 pm    Post subject: Reply with quote
So do you get a dropdown list of alternatives or not, ralye?
rayle
PostPosted: Mon May 11, 2009 3:15 pm    Post subject: Reply with quote
No, just one word, "Undefined" on Firefox, yes to a drop down menu on IE 7.
adamwolfe
PostPosted: Mon May 11, 2009 3:29 pm    Post subject: Reply with quote
Issue appears with IE8 as well Rolling Eyes
Adam
PostPosted: Mon May 11, 2009 4:17 pm    Post subject: Reply with quote
IE8 appears to be an issue itself Shocked Laughing
adamwolfe
PostPosted: Mon May 11, 2009 4:23 pm    Post subject: Reply with quote
Could be Confused
Not sure if its IE8 only but the drop down menus at the top of the pages are all squashed in a vertical sense Exclamation Question as well.
Off topic so I'll go now
Adam
PostPosted: Mon May 11, 2009 4:35 pm    Post subject: Reply with quote
adamwolfe wrote:
Could be Confused
mentioned in another thread - stick ie8 into compatibility mode ;)
end of off-topic :D
