Pocket GPS World :: View topic - time differnt between nuvi and mapsource
eddieo
PostPosted: Thu May 07, 2009 4:43 pm    Post subject: time differnt between nuvi and mapsource Reply with quote
If I work out a route on mapsource on my PC and download it to my nuvi 770 although the distance is the same and route looks the same...the journey on Nuvi is an Hour longer........What am I doing wrong? and which is the correct estimate?
tsdinos
PostPosted: Fri May 08, 2009 10:40 am    Post subject: Reply with quote
maybe it calculates +1hour because of traffic
eyeQue
PostPosted: Fri May 08, 2009 12:31 pm    Post subject: Reply with quote
Within Mapsouce there are options for driving speeds.
Preferences-Routing-Driving Speeds.
Does your unit have the same options.?
Garmin Oregon 300 + Garmin iQue 3600
My Zoned Speed Camera Icons, available here.
eddieo
PostPosted: Sat May 09, 2009 1:46 pm    Post subject: Reply with quote
Thanks!
while I can see the options in Mapsource I have never adjusted anything.....
maybe it adds the hour because of traffic then, seeing as I am going via Paris maybe just as well Rolling Eyes
PaulB2005
PostPosted: Sat May 09, 2009 1:52 pm    Post subject: Reply with quote
Have you got the latest version of MapSource installed?
Version History
Changes made from version 6.15.4 to 6.15.6:
◦Fixed an issue with the file save dialog when the file extension field is hidden.
◦Fixed an issue where MapSource would crash if the route avoidance dialog would be displayed twice.
◦Fixed waypoint category filter issue. Now only waypoints of the selected category will be displayed.
◦Fixed waypoint prefixes.
◦Fixed an issue where MapSource would crash with certain address searches.
◦Fixed memory leaks in the waypoint dialog and map rendering.
◦Fixed an issue with saving gpx files when the file path contains Asian characters.
◦Fixed some hotkey issues.
◦Fixed an issue with searching for certain POIs.
◦Fixed an issue with how unlock codes were stored that caused incompatibilities with applications like Training Center.
◦Support Web Link Extensions in Brazilian Portuguese.
◦Changed waypoint image size to follow the user selected symbol size.
Changes made from version 6.15.3 to 6.15.4:
◦Fixed an issue using custom waypoint symbols installed in the current user directory.
◦Fixed an issue displaying the vertical profile for certain maps.
◦Fixed route issues for routes containing a waypoint more than once.
◦Fixed transfer from and to Garmin Mobile PC devices.
◦Fixed an issue with opening gdb files containing routes with identical names.
◦Fixed an issue where the 'anchor' waypoint symbol was displayed incorrectly.
◦Fixed an issue with map scrolling.
Fixed an issue with route travel time calculations.
◦Fixed an issue with performing address searches.
◦Fixed an issue displaying map labels in print preview.
Latest version is 6.15.6 from here
eyeQue
PostPosted: Sat May 09, 2009 2:27 pm    Post subject: Reply with quote
It has nothing to do with traffic!
Perhaps the unit takes into account the 1 hour difference between UK and France.
The most likely reason - there is an option that does not match either on Mapsource or the unit.
Having travelled thousands of miles on the continent towing the caravan I have never seen your problem.
Give us a start and finish to compare on our units.
Try this one on Mapsource 163 miles - 3hrs - 4mins
N51.26508 E0.61523 to N49.88882 E2.29614
This is with my settings - if yours is different then the Options are different.
Neither of us is wrong only the options are different.
If two Mapsource routes are different then it is possible the options on the unit are not as comprehensive as MapSource.
eddieo
PostPosted: Sat May 09, 2009 2:53 pm    Post subject: Reply with quote
Ah! time difference is probably it........
Calais to Blois (Loire)
mapsource ( v 6.13.7) 292 miles 4.38 hrs
nuvi 292 miles 5,25 hrs
I have not bothered upgrading maps (NT Europe 2008) on either pc or nuvi. may do this next year or buy a new unit and sign up for lifetime maps then. I have had garmin since 2000 and have never upgraded maps annually....I just dont see the point. as I use it primarily for long motorway (notorhome) journeys and routes and addresses dot really change do they......
and just upgrading to V 6.15.6 Smile
Blimey! That looks a lot different on my PC Much clearer and less cluttered..
...do I have to upgrade on the nuvi as well currently 4.70?
eyeQue
PostPosted: Sat May 09, 2009 3:09 pm    Post subject: Reply with quote
295 miles - 5hrs-08mins on MapSource settings as car but 5hrs - 32min as truck [my choice as a caravanner]
You always get a more reliable route on 'truck' settings and the timing is more reliable, but my Oregon does not have that setting - my Garmin iQue does.
eyeQue
PostPosted: Sat May 09, 2009 3:13 pm    Post subject: Reply with quote
Mapsource is on the PC not on the unit.
Never use the updated Mapsource as it elongates the maps East to West.
I have it on the PC but use 6.13.7
eddieo
PostPosted: Sat May 09, 2009 3:20 pm    Post subject: Reply with quote
That is odd! the map of Europe looks fatter and wider....How strange
but def easier on the eye when you scroll in, I thought for a while it had not drawn roads........
retracert
PostPosted: Sat May 09, 2009 6:25 pm    Post subject: Reply with quote
Having travelled that route and beyond more times than I care to remember. The 5+ hour estimate is more accurate that that nuvi one. Even doing that route at maximum permitted speeds (car) and no toilet stops it will still take at least 5 hours, that is assuming you do not have any trouble getting past Paris. Problems in and around Paris have been known to add 2-4 hours to the journey even when trying to avoid them.
eddieo
PostPosted: Sat May 09, 2009 6:45 pm    Post subject: Reply with quote
I work nights...So always drive though the night especially around Paris!
and yep I have taken the wrong turn even with a sat nav on the ring roads:?
will try the "truck" setting...........
thanks everyone for the help!
22.055 (29 May 24)
