Pocket GPS World :: View topic - Corrupt XL IQ Routes
Eagle15
PostPosted: Thu May 07, 2009 9:12 am    Post subject: Corrupt XL IQ Routes Reply with quote
I purchased an XL IQ Routes on 22 April. One of the first things that I did was to back it up, using both the TT facility and Windows Explorer, to my 1 year old Dell Vostro Laptop.
Last night I decided to update the POIs and plugged it into my Laptop. The first thing that I noticed was that in Windows Explorer most of the files had unusual characters in their File Names and other atttibutes. The second thing that I noticed was that TT Home would not start. The cursor just kept flashing. I tried power cycling the XL IQ but it would not start saying that there was no map.
After rebooting both the XL IQ and my Laptop and checking in Windows Explorer again I decided that I would have to Format the XL IQ Drive and restore the files from the Explorer backup.
The full FAT32 format took over 90 minutes.
Copying the files from my Laptop took another 55 minutes .
The XL IQ was then able to operate, however, TT Home still would not start-up. I had to uninstall then install it again to get it working. Everything was now working, except that I noticed that the XL IQ drive had 8 files on it called data*.chk This file suffix implies that they are ‘Recovered File Fragments’.
My questions are:
1. Should the Format take 90 minutes? Normal 2 GB SD cards take a fraction of that time.
2. Should it really take 55 minutes to copy 1.69 GB of files to the TT Drive? Normal 2 GB SD cards take a fraction of that time.
3. Are these data*.chk files anything to worry about?
4. Should I delete these data*.chk files?
GerryC
PostPosted: Thu May 07, 2009 9:28 am    Post subject: Reply with quote
Never having had to format a device, I'm not sure how long it should take though that does sound excessive.
As for the .chk files, they are part of the TomTom system and should NOT be deleted. Microsoft uses that extension for one thing, TomTom for another.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
philpugh
PostPosted: Thu May 07, 2009 9:36 am    Post subject: Reply with quote
Being on the end of a USB connection will slow down file/drive activity quite a bit - still 90 mins is a long time - but as it appears to have found some 'problems' perhaps it was struggling to format the drive?
Phil
PaulB2005
PostPosted: Thu May 07, 2009 9:54 am    Post subject: Reply with quote
Is your laptop USB 1.1 or USB 2?
With the Garmin Nuvis which have USB 1.1 on-board even on a USB 2.0 port it can take that amount of time to transfer a similar amount of data. However TTs have USB 2 on board and i find it only take 4-5 minutes to transfer the same.
How are you connecting the SD card to the laptop? USB Card Reader?
MrT
PostPosted: Thu May 07, 2009 10:00 am    Post subject: Reply with quote
There should be data*.chk files in the root directory.
It can take a long time to write to the TT device but I cannot comment on the format. Ihave just done some read tests on the 530 internal memory on a USB2 port and I am only reading at 2.75MB/s. Writing is usually slower
Corrupted file structures on a TomTom are usually caused by unplugging it from the PC without using the TT-Home "disconnect device" function or the Windows "safely remove device" function.
Drivelux
Eagle15
PostPosted: Thu May 07, 2009 11:03 am    Post subject: Reply with quote
Thank you for the info everyone.
My PC is USB 2.0 . The SD Card format time is taken from the Vostro's built-in Card Reader, and from my TT GO 720 which went up in smoke a couple of weeks ago.
Can't say that I can remember removing the TT without using one of the correct methods, but...
Thanks again.
Eagle15
PostPosted: Fri May 08, 2009 1:56 pm    Post subject: Reply with quote
An 'interesting' reply from TomTom when I asked the same questions -
You can safely delete those files without incident.
When I have more time I might try a full Windows Explorer backup then deleting these files.
dhn
PostPosted: Fri May 08, 2009 2:00 pm    Post subject: Reply with quote
Yeah, I think an Explorer backup would be an EXCELLENT thing to do PRIOR to deleting the data.chk files.
My betting (and that of other, I suspect) is that your unit will not function properly with the data.chk file removed.
PostPosted: Fri May 08, 2009 2:08 pm    Post subject: Reply with quote
Did you get that advice from TomTom? if so someone needs some serious re-training as that will ruin your nav unit, the device won't boot if you remove the data.chk from the root of the device and the dataXX.chk files (XX being a number) from the voices folder are the spoken vavigation voice files so I wouldn't suggest these are touched at all - Mike
Eagle15
PostPosted: Fri May 08, 2009 7:09 pm    Post subject: Reply with quote
The advice did come from TomTom. I've questioned this with them and they've changed their mind. They now say they 'comprise the part of the POI files'.
PostPosted: Fri May 08, 2009 7:14 pm    Post subject: Reply with quote
This confirms they are either stupid or lacking training, the files are voices for either the built in sounds for warnings such as beeps/ bells/ bongs or actual navigation voice files - DO NOT DELETE these, Windows thinks these files are broken, but they are not - when Windows offers to fix the .chk files ignore or decline the offer as it wil ruin the files, the device uses Linux which Windows doesn't quite understand - Mike
falkirk81
PostPosted: Fri May 08, 2009 10:33 pm    Post subject: Reply with quote
My GO 940 copies data to my laptop at a rate of around 6.6 MB/sec and writes it back at a rate of 3.2 MB/sec if thats any help to you!
Tomtom GO 1005 LIVE
iPhone 12
PostPosted: Fri May 08, 2009 11:04 pm    Post subject: Reply with quote
The Go models use USB2 but I believe all the ONE models even the newest ones still use USB 1, so they will be much slower than Falkirk's figures.
Eagle15
PostPosted: Sat May 09, 2009 7:11 am    Post subject: Reply with quote
Thanks for the info gentlemen. Looks like USB 1 on the XL IQ explains it even if it does seem amazing that TT still use USB 1.
Eagle15
PostPosted: Sat May 09, 2009 7:13 am    Post subject: Reply with quote
You can always rely on this Forum to get better quality information than from TomTom.
