Pocket GPS World :: View topic - Installing 3.03 crashes my 2210
Mearns
PostPosted: Tue Jun 22, 2004 10:32 am    Post subject: Installing 3.03 crashes my 2210 Reply with quote
During the installation process I get two warning messages relating to overwriting files......The file Windows\ttnrstwzd.htm is hidden, read-only, or a system file. Would you like to overwrite the existing file? I get the same message for ttrunwzd.htm. So I did overwrite them thinking this was part of the set-up process. They must be something to do with the TomTom Wizard?
The setup then proceeds all the way to the final page where it says it will reset the 2210. Then the HP page shows the blue bar as the unit resets and it then hangs in that state as the blue bar gets to the right side. All the buttons are dead and a hard reset is the only way out.
I restored all my files and tried again, this time not replacing the above files and I have the same result. I've tried both the zipped and .exe files from the TomTom site. Looks like a reinstall from CD is needed.....unless anyone can help?
Tony
nuvi 2460LT plus Brodit mount
iancjc
PostPosted: Tue Jun 22, 2004 10:59 am    Post subject: Reply with quote
I had no problems with 3.03 and my 2210 - the install did do 2 resets but no problems - I also replaced a couiple of files - make sure that the only app running is activesync.
It may well be quicker to make sure all your data is up to date and backed then do a hard reset and reinstall.
TTN6.03 tomtom 7.xx (one)
mpb001
PostPosted: Tue Jun 22, 2004 1:23 pm    Post subject: Reply with quote
i had problems updating 3.03 on my 4150.
it keeps rebooting at the updating gps driver part.
maybe because i down graded from 3.02 driver to 2.xx so i could use my BT gps with other apps.
i will do a hard reset when i get home and try the update again.
where is all the poi data stored? with the maps?
if so i will be ok - just didnt fancy adding everything again Sad
IPAQ 4150 : Kodak 256MB SD.
TTN3 V3.01 : TT BlueTooth GPS.
looking for good all-in-one vent car kit.
dunno
PostPosted: Tue Jun 22, 2004 4:33 pm    Post subject: Reply with quote
I've also got a 2210 had no problems what so ever ,worked a treat ,I've only used it once but the street address was right for the first time
steved
PostPosted: Tue Jun 22, 2004 5:24 pm    Post subject: Reply with quote
I am also having problems upgrading from 3.01 to 3.03 using an iPAQ 4150.
I've had the constant soft reset issue after the GPS upgrade (from 2.07) and also the maps not found error (from GPS 3.02).
Currently have gone back to TT 3.01 and GPS 2.07 having done a hard reset and a back up restore.
Any clues?
Steve.
deesoft
PostPosted: Tue Jun 22, 2004 5:56 pm    Post subject: TTN 3.03 Upgrade Reply with quote
Having earlier today done the upgrade, I was thinking, great, missing places are now back on teh Map.
My joy was short lived.
The inbuilt Bluetoothof my iPAQ h2210 will not work!!!!
I haven't decided where to go next, as I am going away tomorrow (by car) and need the use of TTN3. Obviously I cannot now use Traffic!!
ziggar
PostPosted: Tue Jun 22, 2004 5:58 pm    Post subject: Reply with quote
i also had problems when installing the 3.o3 patch.
it installed fine but when it rebooted it stayed at the loading screen with the progress bar all the way to the right side
no buttons working or life from the screen
ended up doing a hard reset and doing a restore form backup
then tried again and all is now working fine
Z
gokhart
PostPosted: Tue Jun 22, 2004 7:07 pm    Post subject: which rom version Reply with quote
I read that the new version (3.3) fixes the problem with the ipaq 2210/bluetooth on ROM 1.10. I have version 1.00.
Maybe the people who are having problems have the older version of the ROM?
Can people say which version of the IPAQ ROM they have please.
thanks,
deesoft
PostPosted: Tue Jun 22, 2004 9:03 pm    Post subject: h2210 Rom (gokhart) Reply with quote
My h2210 is one of the early models so has versio 1.00
Anyway with reference to my precious posting, I ma going back to version 3,01 of TTN3
dunno
PostPosted: Tue Jun 22, 2004 9:16 pm    Post subject: Reply with quote
yeah i've updated my rom from hp but backup save as you end up with a fresh pc .
Mearns
PostPosted: Tue Jun 22, 2004 9:50 pm    Post subject: Reply with quote
ziggar - looks like you had identical problems to me except you got it to work second time around. Were you using a 2210 as well?
Tony
ziggar
PostPosted: Wed Jun 23, 2004 12:34 am    Post subject: Reply with quote
should have said in me previous post Rolling Eyes
have now added it to me sig
i am using a 2210 with the latest Rom upgrade
Z
ziggar
PostPosted: Wed Jun 23, 2004 12:36 am    Post subject: Reply with quote
WHOOPS
forgot to activate me sig Embarassed :D
Z
iPAQ 2210/ROM 1.10.07, TTN 3.03 and GPS 3.03, Emtac BT, Fuji films 256 CF, Checkpoint 3.2, UKPostCode
MrT
PostPosted: Wed Jun 23, 2004 7:35 am    Post subject: Reply with quote
On mine after the upgrade the London and South East maps worked but the UK did not worl properly. It would crash or exit TT after doing a UK search. I deleted the Great_BritainNavigatorSettings.cfg file and everything worked.
I thought maybe the file had become corrupted in the upgrade and tried an old backup of the file made prior to the upgrade and the same problems occurred again. This also happened on the upgrade to traffic. There must be some part of this file that the different revisions could not handle.
Mearns
PostPosted: Wed Jun 23, 2004 4:39 pm    Post subject: Reply with quote
Well, whatever I did to try and install the upgrade on top of the existing program has failed. So it was back to a hard reset and reinstall 3.01 from the CD. This time the upgrade worked and I have now have 3.03 up and running.
Tony
