Posted: Fri Apr 24, 2009 8:00 pm Post subject: |
You should find four different bmp files the device uses for splash screens:
lowbatteryw.bmp that is displayed when the device shuts down due to a lack of power.
splashw.bmp that is used when the device boots up.
suspendw.bmp that is used as the device shuts off depending upon the setting of the checkbox for "Warn not to leave the device in the car" (Change Preferences/ Safety Preferences) if this isn't ticked you will get the suspendw.bmp displayed.
antitheftw.bmp that is used as the device shuts off depending upon the setting of the checkbox for "Warn not to leave the device in the car" (Change Preferences/ Safety Preferences) if this is ticked you will get the antitheftw.bmp displayed - Mike |
dhn Frequent Visitor
Posted: Fri Apr 24, 2009 8:48 pm Post subject: |
Hence the confusion, I guess. I do have antitheft, not suspend in my root. _________________ David |
wigfield Regular Visitor
Posted: Sat Apr 25, 2009 12:24 am Post subject: |
Ive looked and looked and i just cant see the suspendw.bmp ,I can see the others.
Now this wouldn't be a problem because i unchecked the Warn not to leave the device in the car.I now get the same splash screen
But i thought people were also having a different splash screen when they shut down? I was going to do that.
I could allways change the picture of the antitheftw.bmp,Then i can tick the box: Warn not to leave the device in the car. |
Andy_P Pocket GPS Moderator
Posted: Sat Apr 25, 2009 5:20 am Post subject: |
If you don't have a suspend/suspendw file just make one and add it. It needs to be the same size and format as the others.
You could change antitheftbmp, but it will get overwritten everytime you do a software update. |
Posted: Sat Apr 25, 2009 8:54 am Post subject: |
I did make a suspend file lastnight but it never worked,But ill have another go
EDIT: It works all i can say about it not working lastnight,Well i have no idea maybe it was late and i wasn't thinking right
Cheers |
