Pocket GPS World :: View topic - I Need Help
I Need Help
kittybritt
PostPosted: Thu Apr 09, 2009 5:58 pm    Post subject: I Need Help Reply with quote
Can any body tell me where the favourites are stored on the TT GO 730 if they are in a folder
PostPosted: Thu Apr 09, 2009 6:09 pm    Post subject: Reply with quote
They are saved in the file named "MapSettings.cfg" which you will find in the Western Europe map folder, if you need to open this on the PC to edit the contents consider using POIEdit otherwise what problem do you have, is it possible a map/ software update has cleared them all away? - Mike
kittybritt
PostPosted: Thu Apr 09, 2009 6:37 pm    Post subject: I Need Help Reply with quote
can't find "MapSettings.cfg" in the map the only ones like it are -mapinfo.dat- -MapServerPatch.dat- -MapSettings- -MapUserPatch.dat-
PostPosted: Thu Apr 09, 2009 6:52 pm    Post subject: Re: I Need Help Reply with quote
That looks like the one you are looking for - whats wrong with it though? - Mike
AndyVaughan
PostPosted: Thu Apr 09, 2009 6:54 pm    Post subject: Reply with quote
It will be the mapsettings file then, assuming you have outlook installed and the .cfg files are associated with outlook. Windows will be hiding the file extension from you as it is a known file type. Change your view settings in My Computer to show extensions for known file types.
Andy
kittybritt
PostPosted: Thu Apr 09, 2009 7:02 pm    Post subject: I Need Help Reply with quote
hi mike
there is nothing wrong with it its just i losed all my favourites the last time i updated my TT Embarassed
PostPosted: Thu Apr 09, 2009 7:13 pm    Post subject: Reply with quote
Presuming it was a Map Update, you might be able to use the MapSettings.cfg file from the previous version Backup.
The general consensus is that it is better to change your Favourites to a POI as these are not then overwritten when the unit is updated.
Have a look at This Thread.
AndyVaughan
PostPosted: Thu Apr 09, 2009 7:14 pm    Post subject: Reply with quote
Yep, you will!
Don't be tempted to transfer the mapsettings.cfg file between different versions of Navcore and Maps as it has been known to cause problems.
The consensus seems to be to use POIs instead of favourites - they don't get lost with map/navcore upgrades and are easily transferrable.
Andy
kittybritt
PostPosted: Thu Apr 09, 2009 9:24 pm    Post subject: I Need help Reply with quote
hi thanks everybody got them copy into a new fav's poi many thanks again Laughing
