jksinrod Occasional Visitor
Posted: Mon Mar 09, 2009 5:26 am Post subject: 910 TT drums & sign off screen |
I am using Navcore 8.204 with North America map 815.2019 on my TT 910..... I get a splash screen with no TT drums sound, and no matter how I try I don't see my antitheftW.bmp pic or any goodbye sound? Can someone shed some light on this? Thanks! |
Oldboy Pocket GPS Moderator
Posted: Mon Mar 09, 2009 7:44 am Post subject: |
You would, normally, only get the drum roll if the Unit is Reset (with a pin). Do you have an AntitheftW BMP on the Unit?
As you seem to have a Map/App combination that is not intended for the 910, you can expect there to be some problems. _________________ Richard
dhn Frequent Visitor
Posted: Mon Mar 09, 2009 12:14 pm Post subject: |
To see the antitheftw.bmp graphic, you must check 'warn when leaving vehicle' in Safety Preferences. The warning IS the graphic, not an audio cue. _________________ David |
Posted: Mon Mar 09, 2009 8:02 pm Post subject: |
dhn wrote: | To see the antitheftw.bmp graphic, you must check 'warn when leaving vehicle' in Safety Preferences. The warning IS the graphic, not an audio cue. |
Ahhhh now that makes some sense. I'll give it a try. What about the old .bmp that was shown on shutdown? What if I rename it to that? |
Posted: Mon Mar 09, 2009 9:58 pm Post subject: |
The shutdown file for a wide screen unit must be called antitheftw.bmp. If you have an image already called that and want to keep it, then just do the check in preferences.
If you have a new image you'd like to use, rename the old one antitheftw.bmp.bak or something (in case you want to use it at a later time) and rename the new image to antitheftw.bmp. _________________ David |
Posted: Tue Mar 10, 2009 6:28 pm Post subject: |
Thanks all for clearing this up. Call me dopey, but I liked the drums at startup! |
Posted: Thu Mar 12, 2009 4:43 pm Post subject: |
dhn wrote: | The shutdown file for a wide screen unit must be called antitheftw.bmp. If you have an image already called that and want to keep it, then just do the check in preferences. |
Update on my problem: 910 running navcore_8.204.9718, with North America 815.2019 map. Warn when shut down ticked off. I have tried a couple different antitheftw.bmp, and the issue is that it shows for a microsecond, barely noticeable. I know this is a minor issue but is there any way to get it to stay on for a couple seconds when shutting down? |
Posted: Thu Mar 12, 2009 5:03 pm Post subject: |
Good question.........
As far as I know, the length of time the startup screen and the shutdown screen are displayed are not user defined.
My shutdown is about 2 seconds I would guess....... _________________ David |
