Slicker Occasional Visitor
Posted: Wed Jun 16, 2004 10:52 am Post subject: Toshiba e800 and Road Angel |
Does anyone know where (if possible) I can get a cable to connect my e800 to my road angel.
Paul |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Wed Jun 16, 2004 4:20 pm Post subject: |
That is for a Haicom and it will not work with Road Angel.
There are 2 possibilities for e800.
1. Get the Toshiba serial cable and add a null modem adapter.
2. Use the Toshiba Host cable plus a USB>serial converter.
So the first option is simpler/cheaper. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Thu Jun 17, 2004 11:08 am Post subject: |
Thanks for your reply.
I have managed to find a cable with the Toshiba plug on one end and a ps2 plug on the other.
Now. The problem I have is that I am not sure what to set tom tom up as in the gps settings. What com port should I be using. I have the following options.)
Com1
Com3
Com4
USB Cable
Native IR
Bluetooth GPS (even tho I have the Wi-Fi version)
I have activated the output from my angel (I think) and have a hyper terminal tool on my pda that scans com1 but I see no data.
Any help?
Paul |
Posted: Thu Jun 17, 2004 1:18 pm Post subject: |
update.
I know that the gps data is coming out of the road angel. I have a ps2 - serial cable and I used that with hyper terminal on a laptop.
So - I just need either a different cable, or the correct setting on my PDA.
Paul |
Posted: Thu Jun 17, 2004 2:00 pm Post subject: |
I repeat:
Did you not take this advice? _________________ Pc-Mobile
Posted: Thu Jun 17, 2004 4:50 pm Post subject: |
so,
I need the toshiba to serial (9 pin female) and then a serial (9 pin male) to ps2 male adaptor
Correct? |
Posted: Fri Jun 18, 2004 3:35 am Post subject: |
Slicker wrote: | so,
Correct? |
But YOU CANNOT GET IT !
Unless you make it yourself. _________________ Pc-Mobile
Posted: Fri Jun 18, 2004 10:01 am Post subject: |
I have ordered the toshiba serial cable and I have a ps2 to 9pin serail as well..i
Will see how I get on when the toshiba cable arrives |
Posted: Wed Jun 23, 2004 2:11 pm Post subject: |
update:
I have the toshiba serial cable now and the ps2 to serial cable for the angel.
Am just waiting on an enginner making me a 9pin male to male serial then I can give it a go... |
Posted: Thu Jun 24, 2004 11:52 am Post subject: |
It Worked!! :D |
