TomDavison Lifetime Member
Joined: Mar 02, 2006 Posts: 384 Location: Bedford, England
Posted: Tue Mar 03, 2009 11:37 am Post subject: Ogg files not working on Map 825 |
As usual, I copied the PGPS database into the Map folder, and all the OGG files are in there (TT730T, with V8.302 software and V825.2157 map). When I activate "warn when near", I highlight "Sound Files" and continue. This takes me back to the screen where you type in the distance. Continue, Sound Files still highlighted. Continue, back to distance etc. I can't get any of the OGG file sounds to work. |
Darren Frequent Visitor
Posted: Tue Mar 03, 2009 12:18 pm Post subject: |
Try a soft reset and retry, should resolve that. _________________ Darren Griffin |
jimbo_hippo Frequent Visitor
Posted: Tue Mar 03, 2009 12:48 pm Post subject: |
Tom I did Yorkshire to London last night with the same software and maps as you on a 720 and the .ogg files were fine. I did set them up agai before i left so i'm ot sure if you need to do the same or follow Darren's reset idea (or both). _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
GerryC Pocket GPS Moderator
Posted: Tue Mar 03, 2009 1:11 pm Post subject: |
If you have the ogg files in the folder with the map, you are saying "yes" to "is this the right sound?" even though you hear nothing aren't you?
If you've said "no" at any time to this question, just do a reset and start again saying "yes" when you get to that part. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
sjh4 Occasional Visitor
Posted: Tue Mar 03, 2009 2:05 pm Post subject: |
had same issue, only way i fixed it was to redownload ogg files and copy them back to device replacing existing ones, then tom tom recognised them again |
Andy_P Pocket GPS Moderator
Posted: Tue Mar 03, 2009 4:17 pm Post subject: |
There's always the "method 2" of putting the ogg files into the sounds folder. |
Posted: Tue Mar 03, 2009 11:53 pm Post subject: |
GerryC wrote: | If you have the ogg files in the folder with the map, you are saying "yes" to "is this the right sound?" even though you hear nothing aren't you?
Hi, I don't get that far. When I get the 4 options, and select sound, it doesn't ask me if it is the correct sound, but simply goes back to the screen to set the activation distance. I set this, and get the 4 options, one of which is sound. Select that and get the screen giving the activation distance. (I'm starting to see a pattern here ) |
Posted: Wed Mar 04, 2009 12:16 am Post subject: |
Method 2 |
Oldboy Pocket GPS Moderator
Posted: Wed Mar 04, 2009 7:52 am Post subject: |
TomDavison wrote: | When I get the 4 options, ...... | If you reach the 4 Options Menu, it usually means that there is no OGG file associated with the POI file.
This could mean that the 2 filenames are not identical, or that the association has been lost by the software.
If the files have been in use before, and worked, then we know the filenames are identical.
A 'pin in the hole' Reset usually fixes the association issue, as the reboot initialises a full read of the SD Card/HDD/Internal Memory (which ever it is using). _________________ Richard
