Pocket GPS World :: View topic - Unable to use new map after update
Ratspom
PostPosted: Sun Mar 01, 2009 6:00 pm    Post subject: Unable to use new map after update Reply with quote
I'm a bit stuck on this one but basically I downloaded the UK & Republic of Ireland map for my GO 920T via the TomTom Home application and installed onto the GO 920T which worked correctly since Christmas. I then paid for the 4 yearly updates at £27 ish for the map updates. Today I downloaded the 1st of said updates and upon reboot of the GO 920T it said that it was unable to run the UK & Ireland-26 map on this device ???
Whats happening here? If it let me download the map which ran correctly after being installled why will it now not let me use the updated UK & rep of Ireland map now
Many Thanks
Alan (Mac)
IPAQ 3950 + TT5 Ver 5.21
GO 920T v8.301
Map Western & Central Europe v710.1576
Map UK & Rep Of Ireland v825.2157
View user's profile Send private message Yahoo Messenger
Ratspom
PostPosted: Sun Mar 01, 2009 6:02 pm    Post subject: Reply with quote
ignore this ...posted again in error
GO 920T v8.301
gatorguy6996
PostPosted: Sun Mar 01, 2009 6:12 pm    Post subject: Reply with quote
Assume you mean ignore a duplicate post rather than the original question?
Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr.
Ratspom
PostPosted: Sun Mar 01, 2009 6:27 pm    Post subject: Reply with quote
Yes, sorry I meant to say the double post not the question.
GO 920T v8.301
GerryC
PostPosted: Sun Mar 01, 2009 6:58 pm    Post subject: Reply with quote
What firmware version are you using (tap where it gives your ETA etc then the small box at the bottom right). You may need the updated firmware to run the latest map - otherwise it shows "No map found".
Be sure to back up before and after upgrading using Windows Explorer. See number 1 in the FAQ here.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
Ratspom
PostPosted: Sun Mar 01, 2009 9:12 pm    Post subject: Reply with quote
Ok, I think I know why the new UK & Rep of Ireland map won't work.....I checked the map folder on my TomTom device and there isn't a mapsettings.cfg file ...its missing. Unfortunately I don't have a backup....I know I should have one, anyway does anyone have a copy I could have for the UK & Rep of Ireland map v825.2157
Many thanks in anticipation
Alan (Mac)
GO 920T v8.301
dhn
PostPosted: Sun Mar 01, 2009 9:47 pm    Post subject: Reply with quote
Can you do a pin reset? Hopefully, a new MapSettings.cfg file will get created in the specific map folder.
Ratspom
PostPosted: Sun Mar 01, 2009 9:59 pm    Post subject: Reply with quote
Yeah, already tried that and the mapsettings.cfg doesn't appear to have been created in the map folder Sad
GO 920T v8.301
NeilRitchie
PostPosted: Sun Mar 01, 2009 10:13 pm    Post subject: Reply with quote
I have a similar problem on a TomTom One Xl. Following your post I copied a previous version of mapsettings.cfg to the Western Europe map folder but it didn't make any diffrence.
Now waiting on a reply from Tom Tom Support!! Mad
PostPosted: Sun Mar 01, 2009 10:40 pm    Post subject: Reply with quote
The MapSettings.cfg file will be created when you enter some details that require saving, unless your card is write protected/ read only.
The newer applications and maps don't seem to work with old MapSettings.cfg files so the device will either re-boot continually in a loop or simply delete the file and create a new empty MapSettings file if it cannot read the contents. Consider moving away from using Favourites as they can cause more issues than they are worth - convert your old MapSettings.cfg file to a custom POI file which has a number of benefits:
1/ Application updates won't delete the contents
2/ Map updates won't delete the contents
3/ Ability to store phone numbers against each location
4/ Unlimited number of locations per custom POI
5/ Ability to warn when near (if required)
There are instructions on how to convert the MapSettings.cfg file to a custom POI file on the AQ page (number 15) which can be found Here - Mike
PostPosted: Mon Mar 02, 2009 3:18 am    Post subject: Reply with quote
There's also another topic where lot of people are having the same "You cannot use this map on your unit problem.
Looks like a certificates foul-up by TomTom, nothing to do with MapSettings.
Ratspom
PostPosted: Tue Mar 03, 2009 8:20 pm    Post subject: Reply with quote
I did have a backup that I burnt to DVD just before Christmas, so I copied and pasted the mapsettings.cfg file from the dvd backup to the map folder on my device......but still no joy, still says that I can't use the UK & rep of Ireland map on this device. Looks llike I'll have to email customer support at TomTom.
GO 920T v8.301
richard345
PostPosted: Tue Mar 03, 2009 8:28 pm    Post subject: Reply with quote
Check that the file ypu copied from the DVD does not have the Read Only attribute set. This can be done by looking at the Properties of the file with Windows Explorer.
Anything copied from a DVD or CD has this set by default, I have found.
Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course!
PostPosted: Tue Mar 03, 2009 11:54 pm    Post subject: Reply with quote
Trust me, it's nothing to do with MapSettings.cfg
angusr
PostPosted: Wed Mar 04, 2009 1:56 am    Post subject: Reply with quote
Add me to the list of people who are no longer able to use their Western & Central Europe map after the update to v8.25. Sigh.
Put in a call with TomTom, we'll see what they say...
They really aren't doing well these past few months, are they?
