Darren Frequent Visitor
Posted: Tue Feb 24, 2009 7:03 pm Post subject: |
Gee-Pee wrote: | Darren, do you think a forum for the new Route Planner would be useful Or is just a new thread sufficient......... |
I think a new thread would suffice for now. In fact the thread I started when it was first announced might suffice? It's here. _________________ Darren Griffin |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Tue Feb 24, 2009 7:33 pm Post subject: |
Darren wrote: | Gee-Pee wrote: | Darren, do you think a forum for the new Route Planner would be useful Or is just a new thread sufficient......... |
I think a new thread would suffice for now. In fact the thread I started when it was first announced might suffice? It's here. |
Thanks - really must get some new glasses  _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Tue Feb 24, 2009 7:37 pm Post subject: |
Quote: |
Is it a POI on the 815 map?  |
Havn't looked but assume it is under Tourist Attractions. _________________ Gee-Pee
Calomax Lifetime Member
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Tue Feb 24, 2009 10:52 pm Post subject: |
One of my bugs has been fixed and one hasn't.
I can again disconnect my device using HOME. since the previous update, I've had to use "My Computer"
After using "Operate my Device", Tim is deselected and Kate has bee selected for the navigation instructions. I normally use Recorded voice Tim with Computer voice Kate selected for the warnings. _________________ TT Go Essential |
matthewj Frequent Visitor
Posted: Wed Feb 25, 2009 2:35 pm Post subject: |
The new Beta doesn't happen to allow HD traffic to operate within Home does it? That would be worth having. |
Andy_P Pocket GPS Moderator
Posted: Wed Feb 25, 2009 5:09 pm Post subject: |
matthewj wrote: | The new Beta doesn't happen to allow HD traffic to operate within Home does it? That would be worth having. |
Nope, afraid not.
In fact the SIM card seems to be completely disabled when you "Connect to computer". (At least the "biddly, biddly" interference on my PC speakers stops whenever I connect). |
Posted: Wed Feb 25, 2009 5:13 pm Post subject: |
Gee-Pee wrote: | I'd also like to be able to drag the route from the one offered to an alterntive (as you can do in Autoroute for instance). |
As I'm sure you know... 'Tyre' and the 'Houghi script' can do this too.
These both produce an Itinerary, so you have to be careful to put enough waypoints in, as the TT will still always calculate *it's own* route between each one. |
Posted: Wed Feb 25, 2009 5:24 pm Post subject: |
Andy_P wrote: | matthewj wrote: | The new Beta doesn't happen to allow HD traffic to operate within Home does it? That would be worth having. |
Nope, afraid not.
The GSM interference shouldn't be needed as it can use the computer's internet connection to talk to the servers. For old traffic this used to work, but now it doesn't. Well, it did once for me, but that was because my account got messed up and wouldn't work on the unit, but would in home. So it *could* work if they wanted it to, perhaps by using the devices SIM details in the details sent to the server. Pity though. |
Posted: Wed Feb 25, 2009 9:43 pm Post subject: |
matthewj wrote: | For old traffic this used to work, but now it doesn't. |
This is the first unit I've had with any sort of "Traffic" so I didn't know it used to work in Home. I see your point! |
JulianH Occasional Visitor
Posted: Fri Feb 27, 2009 11:09 am Post subject: |
Does Home v2.6 work with a User account with Vista? v2.5 only seems to work correctly when run from an Administrator account, even running as Administrator in a User account brings up an error - Failure Code 0x80004005 (NS_ERROR_FAILURE) [nslproperties.get]. Home is set to report errors to TT.
Julian[/img] |
tenorplayer Regular Visitor
Posted: Fri Feb 27, 2009 12:05 pm Post subject: |
installed the new Beta home, went to download voices and tried to click on "computer" voices... It said my device is not supported . News to me as I have a 910 |
Posted: Fri Feb 27, 2009 2:29 pm Post subject: |
JulianH wrote: | Does Home v2.6 work with a User account with Vista? v2.5 only seems to work correctly when run from an Administrator account, even running as Administrator in a User account brings up an error - Failure Code 0x80004005 (NS_ERROR_FAILURE) [nslproperties.get]. Home is set to report errors to TT.
Julian[/img] |
Works for me. Only had to confirm install as Admin on upgrade. No problems so far but will shout if I do have  _________________ Gee-Pee
mcqueen Lifetime Member
Posted: Fri Feb 27, 2009 2:43 pm Post subject: |
Julian[/img] |
You need to manually delete the TomTomHome directory left behind in
C:\Users\username\AppData\Local\VirtualStore\Program Files\
from the earlier installation. Once done, re-start HOME and it should run okay. |
Posted: Fri Feb 27, 2009 3:24 pm Post subject: |
from the earlier installation. Once done, re-start HOME and it should run okay.[/quote]
Found two lots of TomTom Home folders, deleted both and, as you said, it now works OK. So why didn't the installer remove these directories??
Julian |
Posted: Fri Feb 27, 2009 3:47 pm Post subject: |
JulianH wrote: | You need to manually delete the TomTomHome directory left behind in
Julian[/quote]
Whoops! You might guess, it worked OK then did exactly the same as before with the same error. Removed the directory, which had reappeared, but still giving the same error.
Julian |
