Pocket GPS World :: View topic - TomTom HOME 2.6 Beta Now Available
Goto page Previous  1, 2, 3, 4  Next
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop
PostPosted: Tue Feb 24, 2009 7:03 pm    Post subject: Reply with quote
Gee-Pee wrote:
Darren, do you think a forum for the new Route Planner would be useful Question Or is just a new thread sufficient.........
I think a new thread would suffice for now. In fact the thread I started when it was first announced might suffice? It's here.
Gee-Pee
PostPosted: Tue Feb 24, 2009 7:33 pm    Post subject: Reply with quote
Thanks - really must get some new glasses Embarassed
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
Gee-Pee
PostPosted: Tue Feb 24, 2009 7:37 pm    Post subject: Reply with quote
Is it a POI on the 815 map? Rolling Eyes
Havn't looked but assume it is under Tourist Attractions.
Gee-Pee
Calomax
PostPosted: Tue Feb 24, 2009 10:52 pm    Post subject: Reply with quote
One of my bugs has been fixed and one hasn't.
I can again disconnect my device using HOME. since the previous update, I've had to use "My Computer"
After using "Operate my Device", Tim is deselected and Kate has bee selected for the navigation instructions. I normally use Recorded voice Tim with Computer voice Kate selected for the warnings.
TT Go Essential
matthewj
PostPosted: Wed Feb 25, 2009 2:35 pm    Post subject: Reply with quote
The new Beta doesn't happen to allow HD traffic to operate within Home does it? That would be worth having.
PostPosted: Wed Feb 25, 2009 5:09 pm    Post subject: Reply with quote
Nope, afraid not.
In fact the SIM card seems to be completely disabled when you "Connect to computer". (At least the "biddly, biddly" interference on my PC speakers stops whenever I connect).
PostPosted: Wed Feb 25, 2009 5:13 pm    Post subject: Reply with quote
Gee-Pee wrote:
I'd also like to be able to drag the route from the one offered to an alterntive (as you can do in Autoroute for instance).
As I'm sure you know... 'Tyre' and the 'Houghi script' can do this too.
These both produce an Itinerary, so you have to be careful to put enough waypoints in, as the TT will still always calculate *it's own* route between each one.
matthewj
PostPosted: Wed Feb 25, 2009 5:24 pm    Post subject: Reply with quote
Andy_P wrote:
Nope, afraid not.
The GSM interference shouldn't be needed as it can use the computer's internet connection to talk to the servers. For old traffic this used to work, but now it doesn't. Well, it did once for me, but that was because my account got messed up and wouldn't work on the unit, but would in home. So it *could* work if they wanted it to, perhaps by using the devices SIM details in the details sent to the server. Pity though.
PostPosted: Wed Feb 25, 2009 9:43 pm    Post subject: Reply with quote
This is the first unit I've had with any sort of "Traffic" so I didn't know it used to work in Home. I see your point!
JulianH
PostPosted: Fri Feb 27, 2009 11:09 am    Post subject: Reply with quote
Does Home v2.6 work with a User account with Vista? v2.5 only seems to work correctly when run from an Administrator account, even running as Administrator in a User account brings up an error - Failure Code 0x80004005 (NS_ERROR_FAILURE) [nslproperties.get]. Home is set to report errors to TT.
Julian[/img]
tenorplayer
PostPosted: Fri Feb 27, 2009 12:05 pm    Post subject: Reply with quote
installed the new Beta home, went to download voices and tried to click on "computer" voices... It said my device is not supported . News to me as I have a 910
Gee-Pee
PostPosted: Fri Feb 27, 2009 2:29 pm    Post subject: Reply with quote
Julian[/img]
Works for me. Only had to confirm install as Admin on upgrade. No problems so far but will shout if I do have Cool
Gee-Pee
mcqueen
PostPosted: Fri Feb 27, 2009 2:43 pm    Post subject: Reply with quote
Julian[/img]
You need to manually delete the TomTomHome directory left behind in
C:\Users\username\AppData\Local\VirtualStore\Program Files\
from the earlier installation. Once done, re-start HOME and it should run okay.
JulianH
PostPosted: Fri Feb 27, 2009 3:24 pm    Post subject: Reply with quote
from the earlier installation. Once done, re-start HOME and it should run okay.[/quote]
Found two lots of TomTom Home folders, deleted both and, as you said, it now works OK. So why didn't the installer remove these directories??
Julian
JulianH
PostPosted: Fri Feb 27, 2009 3:47 pm    Post subject: Reply with quote
Julian[/quote]
Whoops! You might guess, it worked OK then did exactly the same as before with the same error. Removed the directory, which had reappeared, but still giving the same error.
Julian
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop All times are GMT + 1 Hour
Page 2 of 4
