Pocket GPS World :: View topic - 8.301 Upgrade causing language problems
Men9jag
PostPosted: Sat Feb 14, 2009 10:18 pm    Post subject: 8.301 Upgrade causing language problems Reply with quote
I recently connected my tomtom to the pc after having it off for some time. As part of the updates it updated the software inside it. I am currently on version 8.301. Since doing that, i have been having problems with some of the computer voices I have downloaded. Namely the portuguese and Italian one.
Basically instead of speaking in Portuguese or Italian, they read the instructions in english but with a portuguese or italian accent/sound.I have tried deleting these voices and reinstalling it, but the problem persists. Any ideas on what this might be and how to solve it?
The voices I have bee using are Eusbio and Amalia (for portuguese) and Luca and Paola for Italian.
Many thanks
M
dhn
PostPosted: Sat Feb 14, 2009 11:20 pm    Post subject: Reply with quote
Try the reset. If that doesn't help, perhaps the Clear Flash tool found here.
Also, check in Preferences that your language is set to that you wish the computer voice to speak.
Men9jag
PostPosted: Sun Feb 15, 2009 12:10 am    Post subject: Reply with quote
hi Dhn thanks for your reply. I have tried to reset the tomtom sa couple of times. Didnt work. I have also just tried the clean flash tool and still no luck...
thanks for trying thouhg :-)
PostPosted: Sun Feb 15, 2009 12:31 am    Post subject: Reply with quote
And the language setting?
Stewart166
PostPosted: Sun Feb 15, 2009 8:57 am    Post subject: Reply with quote
Sounds like your language is set to English. I have noticed this with Paola before - sounds quite cute really.
All you should have to do is reset the language in preferences.
Men9jag
PostPosted: Sun Feb 15, 2009 9:52 am    Post subject: Reply with quote
Done!that was it, needed to change the language of the whole tomtom. Works fine now. Thanks guys!
I suppose this leads to another question. IS it possible to have the tomtom with english menus and the a different language when it comes to giving you directions?
Hensepens
PostPosted: Mon Feb 16, 2009 7:56 pm    Post subject: Reply with quote
Have different problems. After updating my TT730 (from 8.300 to 8.301) I can't control my TT73- anymore using TOMTOM Home on my PC.
Have issued a problem ticket at TOMTOM.
PostPosted: Mon Feb 16, 2009 8:34 pm    Post subject: Reply with quote
Hensepens, this is quite normal, at some point TomTom will release the required file needed for the PC emulator to work with the new release of Navcore software running on your device.
Whilst this is annoying it is very consistant, I don't think there has ever been a software update for the devices that worked 100% with the Home software since it was first introduced - Mike
PostPosted: Mon Feb 16, 2009 9:15 pm    Post subject: Reply with quote
Guess what? My 920, updated to 8.301 operates absolutely fine in Home. I connected today just to see if there's a new map on the horizon and when there wasn't, out of curiosity I checked the Operate function in case it would download the required file. This is a record and a VERY worrying mystery - a worry because I'm not accustomed to a working update, what's wrong in there? The devil I know is preferable to the devil I don't know. I have never before upgraded the application without suffering the usual loss of "Operate my GO" in TT Home until it downloads the latest file. I have downloaded absolutely nothing since the application update (and I mean NOTHING - I don't touch QuickGPSFix or Mapshare Corruptions with a bargepole!).
PostPosted: Thu Feb 19, 2009 3:25 pm    Post subject: Reply with quote
As I'm sure you know, this is handled by Home downloading the .dll file itself when you attempt to use the emulator, you don't have to download it yourself.
Normally, when it *does* become available, Home says something like "Home needs to download a file to support this function" and gives you a box to click on, but that doesn't seem to have happened this time.
I've been away for a couple of days, but saw in one of the forums that the emulator was working again, so I went to it to get the file downloaded and, as you say, it just seemed to work without any *noticeable* download being done.
PostPosted: Thu Feb 19, 2009 4:05 pm    Post subject: Reply with quote
Yes, Andy, I know. But I was serious when I said "Nothing" - perhaps I should have said I had not asked Home to look for updates and it is not set to do so automatically - I simply fired up Home and without looking for updates or logging in, went straight to Operate my Go and it operated. These days (since the end of the x00s!), "out of the box" and "what it says on the tin" are phrases somewhat outside the ken of TT devices, so that it worked for me got me looking over my shoulder. Thankfully, it had all the usual garbage - wrong map, wrong Application version and so on, so I got back inside my comfort zone quite quickly! Laughing
Calomax
PostPosted: Thu Feb 19, 2009 4:23 pm    Post subject: Reply with quote
My emulator has also just worked perfectly with version 8.301 and I don't have updates automatically set either.
On earlier updates, it said "HOME is downloading a needed file" or similar but, this time just like DennisN & Andy_P, I didn't see a thing.
But when I tried to download my updates just now I got the following:
ERROR: DesktopLib/InstallToDevice/GetInstallable/InvalidArchive1: This file is invalid (archive file): C:\Users\Inez & Keith\Documents\TomTom\HOME\Download\complete\ephemeris\QuickGPSfix-48\Ephemeris.cab
@ .\framework\InstallToDeviceThread.cpp(874)
in .\framework\InstallToDeviceThread.cpp:874
Stack:
0. chrome://tthome/content/ui/bindings/commit.js:74
error(textOrException);
1. chrome://tthome/content/ui/bindings/ttwizard.xml:1033
this._commitFailed(i, commitPage);
2. chrome://tthome/content/logic/util.js:77
return func.apply(obj, arguments);
3. chrome://tthome/content/logic/dllUtils.js:70
this._errorCallback(e);
4. chrome://tthome/content/logic/dllUtils.js:62
this._errorFatal(error);
Time: Thu, 19 Feb 2009 15:15:08 GMT
TT Go Essential
Calomax
PostPosted: Thu Feb 19, 2009 4:36 pm    Post subject: Reply with quote
OK, the first message said
*****\Documents\TomTom\HOME\Download\complete\ephemeris\QuickGPSfix-49 is invalid
soI deleted it and restarted HOME and it updated OK.
Strangely though, the details I quoted earlier says the problem is with
*****\Documents\TomTom\HOME\Download\complete\ephemeris\QuickGPSfix-48
anyway I've now deleted all but the last one.
TT Go Essential
PostPosted: Thu Feb 19, 2009 5:10 pm    Post subject: Reply with quote
Stack:
Interesting, I'm having similar problems today...
I can download fuel prices and MapShare info, but SafetyCams and QPSQuickfix are failing.
Deleting the contents of the relevant download folders usually does the trick, but isn't today. Crying or Very sad
Hensepens
PostPosted: Thu Feb 19, 2009 9:53 pm    Post subject: Reply with quote
Wel, just after I received a message from TOMTOM that they were aware of the problem and are working hard to solve the problem,..... the problem is resolved.
As from yesterday it works fine again.
And yes, I didn;t change anything. I guess there was a sneak update when I started TOMTOM Home on my PC.
