carl_the_cobbler Frequent Visitor
Posted: Fri Feb 13, 2009 11:55 pm Post subject: TyTn II data connection |
Hello,
Tried to pair this wonderful phone with my TT 920, hands free worked great, but data connection didn't. Having read around I see that there is a.cab file available to enable this. Does anyone know if there is a pointer to it, or could anyone help in any other way.
Carl |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat Feb 14, 2009 12:10 am Post subject: |
Perhaps you are thinking of this link _________________ David |
Posted: Sat Feb 14, 2009 10:48 am Post subject: |
Thank you very much for the link
Carl
Added: Still doesn't work any other advice available gratefully received |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sat Feb 14, 2009 11:34 am Post subject: |
It should work, after you installed the cab file by tapping it while using File Explorer on the PDA phone press and hold the power on/ off button until the device puts a warning up about losing data when turing off, just OK this message to reset the phone - you won't lose anything but it does make sure the new DUN Profile is stored correctly.
Is your Tytn-II Orange branded per chance?? - Mike |
Posted: Sat Feb 14, 2009 11:40 am Post subject: |
Got it from 3, Mike.
It sticks at 40% and only finds the hands free facility on the TyTn II |
Posted: Sat Feb 14, 2009 12:00 pm Post subject: |
As long as the DUN Profile is on the phone (which is what the CAB file has added) then it should work, this could be an issue with the software on the 920, you could try running Navcore 8,301 or even 8,320 on your device and see if that offers better results.
My only other suggestions are to delete the Phone from the TomTom and delete the TomTom from the phone, now try setting it up from scratch, failing this you could flash the phone with a different ROM, but this is a rather drastic move and will void any warranty you have on the handset.
I have had similar in the past when using HTC phones with the TomTom for data connections, a software update can sometimes remove the capability to use the phone to the same leval as was previously possible - Mike |
Posted: Sat Feb 14, 2009 12:27 pm Post subject: |
Once installed is there anything I need to switch on or should it just happen? |
Posted: Sat Feb 14, 2009 12:51 pm Post subject: |
No there is nothing to switch it simply adds the DUN Bluetooth profile to the device which is what the TomTom needs for a data communication via your mobile phone - Mike |
Posted: Sun Feb 15, 2009 6:47 pm Post subject: |
Well I can' get it to work. 3 have given up on me. I have trawled the web looking for any kind of ideas and nothing. Cheers for the help fellas.
Carl |
Posted: Sun Feb 15, 2009 6:49 pm Post subject: |
Oops |
perussell Frequent Visitor
Posted: Mon Feb 16, 2009 11:10 am Post subject: |
I know this may not be of much help but just to confirm that after Mike had sent me the link to the .cab file earlier last year I followed the instructions, (it did take a couple of attempts) and since that time have had no issues with my HTC TyTn II (a.k.a. Vodafone V 1615). At the time of installation I was using a pre-v8.3 Navcore but it was still working fine after the v8.3 "downgrade" - I had a subscription to GPRS traffic and all was OK (as far as that was concerned) - as for Kate - enuff said!
My HTC also works absolutely fine with my 540 LIVE although I am not using GPRS traffic anymore |
Posted: Mon Feb 16, 2009 2:26 pm Post subject: |
When you say followed the instructions, doesn't the .cab file just install what is required?
Does anyone have any idea what it does install so I can see if they are there and in the right place?
Carl |
Posted: Mon Feb 16, 2009 2:31 pm Post subject: |
I mean that Mike Alder sent it to me and told me to how to unzip, where to put it etc. I can still see the file using the Programs/File Explorer option where it sits as a 60.6k file entitled WM6_BT_DUN |
Posted: Mon Feb 16, 2009 2:37 pm Post subject: |
yep that's the one I have.
Carl |
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Mon Feb 16, 2009 2:59 pm Post subject: |
The reason that HTC do not install the DUN is that they provide an alternative in Internet Connection Sharing where the device appears as a Network Access Point and you connect to that service by USB or Bluetooth and it then connects to the GPRS service. I think that TomTom devices do not understand the Network Access Point service. _________________ Drivelux |
