arkiboys Regular Visitor
Posted: Fri Feb 13, 2009 10:52 am Post subject: Distance & Time |
Using a Garmin nuvi 250, how do I find the milage and time it takes to get to the destination p lease?
Thanks |
greg_m Occasional Visitor
Posted: Fri Feb 13, 2009 12:15 pm Post subject: |
i don't have my nuvi with me, but as i remember tap on the 3d map, it will show you a route turn-by-turn. then on this screen touch the 'show map' on the bottom and you will see distance and time to get to a destination (as well as 2d map of a journey). |
Posted: Fri Feb 13, 2009 12:49 pm Post subject: d & t |
No, that is not it.
Thanks |
Posted: Fri Feb 13, 2009 1:27 pm Post subject: |
Usually (although it can change from model to model) you get to the the 3d map and then tap the bottom right corner where it says how far to next turn. It'll bring up details of that turn, then use the down arrow to scroll to the end of the instructions and it'll tell you the total distance and time. |
Posted: Fri Feb 13, 2009 1:41 pm Post subject: dt |
I remember seeing the turn by turn list once. Can not find it now but will try again...
Is there somewhere where it sums up the time and distance for all these turns and gives the figures as the total distance and time to get from A to B?
Thanks |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15148 Location: Bradford, West Yorkshire
Posted: Fri Feb 13, 2009 2:02 pm Post subject: Re: dt |
arkiboys wrote: | I remember seeing the turn by turn list once. Can not find it now but will try again...
Thanks |
yes, see paul's post above!
MaFt |
Posted: Fri Feb 13, 2009 2:03 pm Post subject: |
Quote: | I remember seeing the turn by turn list once. Can not find it now but will try again...
Thanks |
Yes, i described it in my above post. As you go through it adds up the distances and time so the last one tells you the totals. |
Posted: Sat Feb 14, 2009 1:17 am Post subject: |
my guide from above post works on my Garmin 255W, but you have to tap top bar (when next turn shows etc.), not 3D map. Then 'show map' and it shows you distance and time there. but I guess it might be slightly different from model to model. |
