Pocket GPS World :: View topic - Newbie how to find car charger polarity?
PoloM
PostPosted: Wed Feb 04, 2009 2:14 pm    Post subject: Newbie how to find car charger polarity? Reply with quote
I bought an LG LN505 on sale it was new but no car charger included.
I phone LG and they wanted a staggering £45 for a charger which is almost the cost of the unit.
I've searched the manual but there is no information on the charger specs.
On the unit it says 5v dc at 2A but no symbol to indicate the polarity whether the charger should have a positive centre or negative centre.
It uses a jack type charger rather than a USB type.
I have borrowed a multimeter and was wondering if anyone can advise how to work out the charger polaity required from the Sat Nav unit itself?
Many thanks
PostPosted: Wed Feb 04, 2009 4:24 pm    Post subject: Reply with quote
I Googled for the "Lg LN505" and the first thing it came up with was this:
£3.95 power supply
Not even worth thinking how to work it out at that price! Very Happy
PoloM
PostPosted: Wed Feb 04, 2009 5:55 pm    Post subject: Reply with quote
£3.95 power supply
Hi Andy, thanks for your reply.
I received a charger from those people today, the company goes under various names on the net and eBay but is still a company called 'M-99'.
I tried the charger... the jack fitted OK but when plugged into the cigarette lighter I saw the unit power up then the screen went very very bright and then started to get lines appearing and then faded out.
Needless to say I'm very worried about this and am wondering whether the charger may have fried my unit. Sad
PostPosted: Wed Feb 04, 2009 7:27 pm    Post subject: Reply with quote
Oh dear.....
That does sound pretty bad.
What you could do now is use the multimeter you borrowed to see what the output voltage of the charger is now (not plugged into anything!)
If it is significantly more than 5 Volts (either polarity), then I think you would have a case against them.
PoloM
PostPosted: Wed Feb 04, 2009 8:17 pm    Post subject: Reply with quote
Andy_P wrote:
Oh dear.....
Hi Andy,
Just did as you just said and metered the charger and it turns out to be a Positive centre pin polarity.
The output when plugged into the cig-lighter was 5.58v Confused ...is that above the normal tolerances for a 5v dc requirement?
Also if the polarity of the charger was wrong would it be the case that the sat nav unit would not have powered up and just burnt out? Question
Pocketgps
PostPosted: Wed Feb 04, 2009 8:53 pm    Post subject: Reply with quote
Just to cut in on your posts with Andy.
5.58v is fine under no load.
Can we ask how you obtained your gps unit and why did it not have a car charger included as they usually come with one as standard.
PoloM
PostPosted: Wed Feb 04, 2009 9:09 pm    Post subject: Reply with quote
It was a Manager's Special at Halfords as a display unit kept in a cabinet but was not used powered. It came with all accessories apart from the charger which I thought would be easy to get. Sad
aj2052
PostPosted: Thu Feb 05, 2009 1:49 am    Post subject: Reply with quote
Not neccesarily so, I bought the LG cookie retail 3 weeks ago and it did not come with a car charger, we seem to be getting into the situation where manufactures are dropping out the things we might consider standard, It started with printed manuals now on CD. most plugs nowadays are centre pin positive as standard, as most units now seem to be standazing on 4.7v batteries, all of my units are usb charging and to avoid the increasing collection of differeing charging leads I am trying to go the way of a car and mains charger with USB charging output, manufactures take note.
Moto G5s Plus, Sygic 17.4.8
aj2052
PostPosted: Thu Feb 05, 2009 2:00 am    Post subject: Reply with quote
To Add to above most items nowadays most units are not polarity consious, because it only takes two diodes to make it so, but the then in these days of price cutting manufactures who knows,
In my opinion I would take back to halfords because unless it was marked as having a fault it would still be covered under the sale of goods act, explaining that you have bought a LG charger and found it faulty and unfit for purpose.
Pocketgps
PostPosted: Thu Feb 05, 2009 6:10 am    Post subject: Reply with quote
As aj2052 said, I would return it to Halfords and see what they say.
If you are unable to charge the unit, and LG want so much for a charger, then I cannot see how Halfords can refuse you a refund as it make it so expensive. I would not mention that you have bought a charger for it. Just that the unit does not work if that is the case.
