tkerby Lifetime Member
Fozzee Regular Visitor
Posted: Thu Jan 29, 2009 7:27 pm Post subject: Re: New Go Mounts Available |
These have been available for a while see other posts! |
Darren Frequent Visitor
Posted: Thu Jan 29, 2009 7:53 pm Post subject: |
Actually the Active Dock with iPod Support hasn't. The active dock for fixed install was available before Christmas but the windscreen mount dock with iPod support wasn't for some bizarre reason.
So it is new.
 _________________ Darren Griffin |
Two of those mounts are indeed new, the windscreen holder with Line Out and iPOD/ RDS-TMC sockets hasn't been seen till now see Here also a mount with iPOD and line out sockets and an integral RDS-TMC receiver is listed which is new Here - Mike
itaylort Occasional Visitor
Posted: Thu Jan 29, 2009 8:03 pm Post subject: |
Could anybody solve this for me?
This is from the tomtom site describing the new active ipod mount.
Quote: | Listen to music and voice instruction over your car stereo using the line-out on the dock. (audio cable not included).
With only one socket how can you have the ipod connected to your device and line out to your stereo, at the same time?
Is ther a twin splitter jack cable available?
Many Thanks
Ian |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Thu Jan 29, 2009 8:05 pm Post subject: |
When you use the version with the RDS TMC receiver, can this be disabled so HD traffic is used in preference and how do you do this?
If you plug an existing TMC in the x40 range it disables the HD Traffic. _________________ Drivelux |
Posted: Thu Jan 29, 2009 8:13 pm Post subject: |
£50 for the mount with rds traffic is not bad given the price for individual components. I'd note though that its now disappeared from that page... |
Posted: Thu Jan 29, 2009 8:18 pm Post subject: |
If you use the RDS-TMC mount the device will use HD Traffic when it can get a signal and is within the country of intended use. Lose the HD signal due to server issues or poor signal coverage of the Vodafone network the unit switches to the RDS-TMC, it will auto switch back to HD once the signal returns or the issue preventing data is resolved.
Should you take the unit out of the UK assuming you bought the x40 here then it will switch to RDS-TMC then switch back to HD mode once you return to this country - Mike |
Posted: Thu Jan 29, 2009 8:27 pm Post subject: |
itaylort wrote: | With only one socket how can you have the ipod connected to your device and line out to your stereo, at the same time? |
There are two sockets, iPod and Line Out. See image below:
Andy_P Pocket GPS Moderator
Posted: Fri Jan 30, 2009 12:44 am Post subject: |
Also the range of movement possible on the ball joint is quite a lot less then on the standard mounts.
With the sucker on a flat horizontal surface, and the mounting shoe swivelled as far as it will go, the screen is still tilted back at about 20-25 degrees, so there might well be reflection problems. |
Bukton Lifetime Member
Posted: Fri Jan 30, 2009 2:49 am Post subject: |
Sorry if off topic. Which phones provide the RDS reception - WM, Android, symbian?  |
Posted: Fri Jan 30, 2009 6:29 am Post subject: |
Bukton wrote: | Sorry if off topic. Which phones provide the RDS reception - WM, Android, symbian?  |
No phone is required. The RDS-TMC is either built-in or uses an external receiver. _________________ Tim |
Posted: Fri Jan 30, 2009 8:52 am Post subject: |
Andy_P wrote: | Also the range of movement possible on the ball joint is quite a lot less then on the standard mounts. |
Which mount is this Andy? The RDS mount? _________________ Darren Griffin |
Posted: Fri Jan 30, 2009 8:55 am Post subject: |
Are you just referring to the RDS_TMC version here as this will rule out this mount for me as I need around 5 degrees angle for optimal viewing on a dash mount.
Also the instructions saying that the aerial must be extended fully downwards makes me think that it could not be if mounted on top of the dash as there is only around 5cm clearance between the base of the faceplate and the dash.
Could this mount be cannibalised with an original to give more movement? _________________ Drivelux |
