Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3, 4 ... 33, 34, 35  Next
linknet
PostPosted: Tue Jan 27, 2009 12:21 pm    Post subject: Reply with quote
Added Version 6.02 Smile
This should now be fully compatible with both of these versions:
iGO8 PDA Version 8.3.2.64029 dated 7th November 2008
iGO8 PNA Version 8.3.2.64873 dated 13th November 2008
Plus some minor cosmetic changes.
linknet
Patrick2008
PostPosted: Tue Jan 27, 2009 2:01 pm    Post subject: Please help Reply with quote
Hello guys,
I can't get the Ultra skin working.
If i select it and iGo will restart i get an error:
FFUIERROR: Unknown object indentifier
Indentifier = [vGetUpdates]
Script "st_Start_init"
command 45
Can someone help me because the ultra skin is the only skin for me. I refuse to use others. And default is nothing compared with the Ultra skin.
linknet
PostPosted: Tue Jan 27, 2009 4:23 pm    Post subject: Re: Please help Reply with quote
Which version of iGO8 are you using ?
linknet
Patrick2008
PostPosted: Tue Jan 27, 2009 4:42 pm    Post subject: Reply with quote
8.3.2.64873
On a TyTn II
linknet
PostPosted: Tue Jan 27, 2009 4:51 pm    Post subject: Reply with quote
Patrick2008 wrote:
8.3.2.64873
On a TyTn II
If you look on page 1 of this topic "LolitaDamore" reports it as working on the same device.
Have you got the correct data.zip for version 8.3.2.64873 ?
linknet
Patrick2008
PostPosted: Tue Jan 27, 2009 5:03 pm    Post subject: Reply with quote
I supose the data.zip is correct. How can I check it? If i look at the options menu it shows 8.3.2.64873. If i delete the save map on my TyTnII it works again. But as soon as i change the skin to Ultra I will get the FFUI error. With other skins i dont have this problem. But then the other skins are the problem, they all suck.
Giantbiker73
PostPosted: Tue Jan 27, 2009 5:11 pm    Post subject: Reply with quote
linknet wrote:
Giantbiker73 wrote:
What does the setting "Pop-Up Second Route Event" do? Doesn't seem to make a difference when settings are changed.
I've added a descriptive graphic to the website screenshots page. Smile
This fully explains the "Pop-Up Second Route Event" settings.
linknet
Marvellous Very Happy
Now I understand the setting correctly, wonderful. Thanks for your effort in clarifying.
I've put the 6.02 skin on my TyTnII running version 8.3.2.64029, simulation runs fine. I'm travelling back home tomorrow so this will be a good test (although I strongly doubt the skin going wrong on me, ofcourse).
Will report if problems occur.
linknet
PostPosted: Tue Jan 27, 2009 5:13 pm    Post subject: Reply with quote
I'm pretty sure that you are using the data.zip from version 8.3.1.xxx which is not compatible and you will get the error.
Check your PM's Wink
linknet
Patrick2008
PostPosted: Tue Jan 27, 2009 6:00 pm    Post subject: Reply with quote
I have ckecked my PM Smile
jkare
PostPosted: Tue Jan 27, 2009 8:18 pm    Post subject: Reply with quote
Hello Linknet,
I'm glad your back.
I have a problem I can not find the menu "3D Smart Zoom settings".
I see on your site in the screenshots but I can not find in the settings on my PDA.
Can you help me
thank you
linknet
PostPosted: Tue Jan 27, 2009 8:29 pm    Post subject: Reply with quote
3D navigation map "Tap" then "Tap and Hold" on the right hand zoom button at the bottom of the screen. Wink
linknet
tekilachat
PostPosted: Wed Jan 28, 2009 9:14 am    Post subject: Reply with quote
Welcome back linknet, I'm very enjoy
I'm Tek', but, this nickname already exist here ;)
we have job to do, french translation, french voice for speedcam ;)
tekilachat
PostPosted: Wed Jan 28, 2009 9:45 am    Post subject: Reply with quote
first french translation :
Blocked Roads="Routes Bloquées"
Block Road="Bloquer une Route"
Remove Block="Retirer la route bloquée"
Deleting blocked road.="Supprimer la route bloquée."
Deleting all blocked roads.="Supprimer toutes les routes bloquées."
Find Map Mode="Trouver Mode Carte"
Find Map Mode Settings="Trouver Reglages Mode Carte"
Key Sounds Volume="Volume du Son des Cases"
Next Turn="Prochain virage"
Pop-Up Info Settings="Réglages Fenetre Info"
Pop-Up Info Panel="Panneau Fenetre Info"
Display Visible POI's Only="Afficher seulement les POIs visibles"
Maximum Search Radius="Rayon max. de recherche"
Lane Information Settings="Paramètres pour l'information des voies"
Menu Button Fade Out="Bouton Menu disparaissant en fondu"
Trip Data Overspeed Warning="Signaler un dépassement de vitesse"
Show Speed Limit="Voir Limitation de Vitesse"
Show Speed="Voir Vitesse"
Tilt Up to:="Inclinaison jusqu'à:"
Tilt Down to:="Incliner à:"
Map Full Screen Settings="Paramètres de la carte plein écran"
Second Route Event="Seconde manœuvre"
Second Route Event Show at:="Afficher la seconde manœuvre à:"
Second Route Event Show if Less than:="Afficher la seconde manœuvre si inférieur à:"
Show House Numbers at:="Afficher Numéros Maisons à:"
linknet
PostPosted: Wed Jan 28, 2009 9:46 am    Post subject: Reply with quote
First french translation :
That looks good, I'll add it to a language file and post it as soon as I can find time.
linknet
LolitaDamore
PostPosted: Wed Jan 28, 2009 11:46 am    Post subject: Reply with quote
I would only change "Fenetre" by "Fenêtre" Cool
Page 3 of 35
