Taps Occasional Visitor
Posted: Sun Jan 18, 2009 5:45 pm Post subject: Locking up map source with overlay |
Hi, Could any one advise I have a garmin 2610 with the europe map 08 I could install the speed cameras ok until after the end of Dec, it now locks up the map source and quote product 702, may have stated after updating menbership, any Ideas, ps I can reload previous down loads ok
Cheers Taps |
WiRED Regular Visitor
Joined: Apr 01, 2005 Posts: 125 Location: Berkshire, UK
Posted: Sun Jan 18, 2009 5:58 pm Post subject: |
Interesting. I upgraded Mapsource yesterday to the latest version (6.13.4) and when I started it up, I got that message about product 702. However, I closed it down, started it again and it was fine. I've started it several times since and I can't repeat the error, so I put it down to the Mapsource upgrade process.
However, are you saying you have a recreatable failure, which goes away if you use an older version of the maps? If so, I would be interested to know which version of Mapsource you have and which versions of the overlay work and don't work. Also, the path to the folder where you install the Safetycameramap would be helpful as well.
I should point out, I create the overlay map for PocketGPSWorld, so I should be able to help get to the bottom of this.
/WiRED |
eyeQue Lifetime Member
Posted: Sun Jan 18, 2009 8:58 pm Post subject: |
Ok, I've sorted it out now.
I managed to introduce a typo into the build process of the pMobiles product. Interestingly, it only seems to upset recent versions of Mapsource. The reason I hadn't noticed it is that I appear to have 2 versions of Mapsource installed and I've been testing releases with the old version
Anyway, its fixed now and anyone affected by this should download version 7.013.2. I've sent it to MaFt but it may take a little while before it makes it onto the downloads page.
/WiRED |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Mon Jan 19, 2009 12:01 pm Post subject: |
this has now been updated (11am, 19th jan 09) |
Posted: Mon Jan 19, 2009 8:50 pm Post subject: map source overlay code 702 |
Many thanks the new updated download works a treat.
loads up ok now
Cheers Taps |
