Pocket GPS World :: View topic - 540 light sensor useless?
markmcrobie
PostPosted: Fri Dec 19, 2008 12:44 pm    Post subject: 540 light sensor useless? Reply with quote
Any else find the setting to auto turn on night mode useless? Mine's sometimes turns on night mode during broad daylight, and other times stays on day mode even though it's dark out.
PostPosted: Fri Dec 19, 2008 1:10 pm    Post subject: Reply with quote
Yes, its hopeless!
markmcrobie
PostPosted: Fri Dec 19, 2008 1:16 pm    Post subject: Reply with quote
Yes, its hopeless!
Cool, so I dont have a faulty unit then?
How hard can it be to include a light sensor that works?
PaulB2005
Often wondered why TT didn't implement the same method Garmin did. As the sat nav knows its longitude and latitude, the date and the time it can calculate dusk and dawn and just change when needed.....
PostPosted: Fri Dec 19, 2008 1:26 pm    Post subject: Reply with quote
That would be a much simpler and much more useful set-up.
dbarfoot
PostPosted: Fri Dec 19, 2008 3:21 pm    Post subject: Re: 540 light sensor useless? Reply with quote
It seems to work mostly OK on my 540. It seems to be set a bit wrong in that it switches to night mode a little early but not excessively so. It switches to night mode in tunnels and heavy tree cover too.
A couple of times it has stopped working which has required a hard reset to fix.
I'm not sure I completely understand how it works as even when it's working "normally" I don't seem to be able to make it switch by just covering the sensor, it seems to need a "natural" change in the light levels.
Dave.
markmcrobie
PostPosted: Fri Dec 19, 2008 3:40 pm    Post subject: Re: 540 light sensor useless? Reply with quote
I found this strange too - completely covering the sensor with your finger has no effect
PostPosted: Fri Dec 19, 2008 4:13 pm    Post subject: Reply with quote
The light sensor will only "work" whith the unit in the car dock - Mike
mikero
PostPosted: Fri Dec 19, 2008 5:44 pm    Post subject: Reply with quote
Mine switched to the "night" setting the other day in broad daylight and I was unable to see it properly. I now switch between day and night manually, it is far less bother.
IanS100
PostPosted: Sat Dec 20, 2008 12:27 am    Post subject: Reply with quote
My 520 goes to night view at the mere hint of a cloud in the sky. I think TomTom are under the impression that we walk round with our Sat Nav's held at arms length rather than having them installed in a vehicle.
Like mikero I've now reverted to changing it manually.
PhilDPerv
PostPosted: Sat Dec 20, 2008 1:03 am    Post subject: Reply with quote
Glad to see mines not the only unit with an issue with this feature , sometimes its switches to night vision when dark , sometimes it just dims the screen but stays on day colours , sometimes it does nothing at all , Okay it's not a major issue to manually switch , but still I would like the item to do what it says on the tin.
Still impressed with the purchase over all though
mcwarre
PostPosted: Sat Dec 20, 2008 4:54 pm    Post subject: Reply with quote
Cool I thought that it was just mine! Manual is so Old Skool............
Mind you, Manuel was so Cool in Faulty Towers!!!!!!!!!!!!!!
psyskiesman
PostPosted: Sat Dec 20, 2008 5:33 pm    Post subject: Reply with quote
Well my 720T works perfectly, even varying brightness levels depending upon just how dark/light it is outside the car. It is connected through the cigarette lighter socket, not a cradle of any sort.
exportman
PostPosted: Sat Dec 20, 2008 5:38 pm    Post subject: Reply with quote
I have a rider 2 and pretty much it works OK.
Andrew
peterc10
PostPosted: Sat Dec 20, 2008 8:18 pm    Post subject: Reply with quote
Bet Jonathan Ross and Russel Brand wouldn't agree. Although his daughter .......
Peter
HTC Sensation
Copilot for USA
23.054 (28 May 25)
