welshgasman Regular Visitor
Posted: Tue Dec 16, 2008 6:48 pm Post subject: Garmin i3 isn't working on batteries? |
My i3 has suddenly stopped working on batteries.
I do tend to use it in the car on a usb lead, but I am lending it to a friend for use in a city.
Just went and put fresh batteries in (tried two sets) and it will not boot up. Tried a reset, no difference.
Batteries tested in my Psion OK.
Any ideas please?
TIA |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Dec 16, 2008 8:06 pm Post subject: |
Presuming you are fitting the batteries the correct way round, then the only other thing to check is if the battery leads inside the i3 are ok.
Think you need a torx T5 or 6 to remove the 4 fixings. BUT, you then need to force open the casing and this WILL mark (damage) it. |
Posted: Tue Dec 16, 2008 8:12 pm Post subject: |
Yes, I am putting them in the correct way, but it is wise to check. :-)
They will just have to live with it for now and use only in the car.
I'll take it apart when they give it back.
Think I might give Garmin a ring tomorrow as well.
Thanks for the reply. |
Posted: Tue Dec 16, 2008 8:19 pm Post subject: |
I think you might have seen This post before, but it does show how to open the i3, and I guess you still have the screwdrivers from last time - Mike |
Posted: Tue Dec 16, 2008 8:43 pm Post subject: |
Thanks Mike,
I do have the screwdrivers from taking apart my other i3, but I'll check the circuit with a meter when I get it back before considering taking this one apart.
It is well looked after so I'm suprised this has happened.
mikealder wrote: | I think you might have seen This post before, but it does show how to open the i3, and I guess you still have the screwdrivers from last time - Mike |
Posted: Wed Dec 17, 2008 2:45 pm Post subject: |
Contacted Garmin, they could not offer any advice.
Repair would be just over £73 and new maps about £50.
It still works fine for now, but when it gives up the ghost it will be cheaper to get a new one.
As I am unemployed at the moment, I do not need it as much as I used to either. :-) |
