Pocket GPS World :: View topic - 940 Favourites problem
hijacker
PostPosted: Sat Dec 06, 2008 10:47 am    Post subject: 940 Favourites problem Reply with quote
The format of my Favourites keeps changing.
Initially you type a name for your Favourite and this is displayed on the nav.
However after a few uses of the 940 the Favourite name is disappearing for all my entries, instead leaving behind the physical address of where my Favourite is.
EG:
I store a Favourite as "Bananaman". The associated address with this is 22 Acacia Avenue.
For a short period the favourite is correctly reported as "Bananaman".
However it then changes to "22 Acacia Avenue". The "Bananaman" is gone!!
Any takers??
TT GO 1005
MrT
PostPosted: Sat Dec 06, 2008 11:35 am    Post subject: Reply with quote
My favourites have not changed at all on my 940 but they were all entered as points on the map rather than addresses. I usually enter them this way as the numbers for addresses are often a few houses out.
PostPosted: Sat Dec 06, 2008 4:22 pm    Post subject: Reply with quote
Not seen that myself, but it's a good bug!
Is it repeatable?
Can you think of anything you might do that prompts it to happen (e.g. connecting to Home?)
hijacker
PostPosted: Sat Dec 06, 2008 9:19 pm    Post subject: Reply with quote
Is it repeatable?
Would you think using the MapSettings.cfg file copied across from my previous 930T would cause any problems??
TT GO 1005
pushandpull
PostPosted: Sun Dec 07, 2008 11:31 am    Post subject: Reply with quote
I have experienced this same problem twice on my G940.
However I have also been having problems with Fuel Prices and the last advice I got from TT was to:-
[a] Make a backup of my system.
[b] Use TTHome to remove the Application.
[c] Delete the Files (but NOT the Folders) from the Root directory.
[d] Use TTHome to reinstall the Application.
This I did and then copied back my MapSetting.cfg to restore my Favourites.
Since then the problem has not re-occurred
Of course that doesn't mean it won't if it is indeed a bug!!!
…..Ken (Heywood, U.K.)
Nobody is perfect, which is why I'm called nobody!
TT940 Live TTG920T, TTG700, TTG Classic, Nuvi1410
Larok
PostPosted: Sun Dec 07, 2008 11:38 am    Post subject: Reply with quote
yep, mine did that once after a firmware update.
hijacker
PostPosted: Sun Dec 07, 2008 11:50 am    Post subject: Reply with quote
Is point [b] removing the TomTom Application from the unit itself?
TT GO 1005
Oldboy
PostPosted: Sun Dec 07, 2008 5:05 pm    Post subject: Reply with quote
In a word, yes.
You have the option to remove items from the Device or the Computer. Use the Device Tab.
PostPosted: Sun Dec 07, 2008 11:24 pm    Post subject: Reply with quote
YES!
Copying the MapSettings.cfg file across from older software versions always used to work, but has caused enough problems on recent versions (or especially on a change of machine) for me to decide I will NOT do this ever again.
Yes it's a bit of a bore setting up things as you like them again, but I'm firmly convinced that more and more odd behaviour is being caused by people continuing to use this "short cut".
hijacker
PostPosted: Mon Dec 08, 2008 7:37 am    Post subject: Reply with quote
Gonna revert to the CFG file then that came with the device and try that.
TT GO 1005
PostPosted: Mon Dec 08, 2008 9:42 am    Post subject: Reply with quote
If you have a day one back up from prior to you adding your Home Location to the device the chances are you won't have a MapSettings.cfg file in the backup.
Just remove the MapSettings.cfg file from the the map folder then switch on the device, it will create a new (empty) MapSettings.cfg file - Mike
hijacker
PostPosted: Mon Dec 08, 2008 10:26 am    Post subject: Reply with quote
Thanks for the reminder but I renamed my original CFG file to 'MapSettings940.cfg' before I pasted over my 930s CFG file and left it on the device just in case I needed to switch back to it.
TT GO 1005
