Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Wed Dec 03, 2008 11:30 am Post subject: |
It might be worth asking one of the other owners in an existing thread for help? _________________ Darren Griffin |
![](modules/Forums/images/avatars/gallery/Sphere_animated2.gif)
Posted: Wed Dec 03, 2008 12:18 pm Post subject: |
Not familiar with the Kenwood units but as they are Garmin based can you try the following.
Where To?, Extras, Custom POIs. Are the cameras listed there? |
aemdee Occasional Visitor
Posted: Wed Dec 03, 2008 12:28 pm Post subject: |
It just had one option...Delete All. Nothing else. |
Posted: Wed Dec 03, 2008 12:41 pm Post subject: |
If you zoom right in on a town can you not see the POIs and cameras?
User manual is here (8.8 Mb PDF) but doesn't cover the Navigation part.... |
Posted: Wed Dec 03, 2008 12:50 pm Post subject: |
Another method.
Delete everything off the SD card. Load the SD into the PC, run POILoader and select "Garmin Device", then choose the SD Card. Let it load the database to the card and then try.
I forgot "Garmin Device" usually allows you to choose either the internal unit memory or the SD Card in the device slot. Hopefully it'll allow you to load to a card in a card reader. this should ensure the folder structure is correct. |
Posted: Wed Dec 03, 2008 2:27 pm Post subject: |
Thanks for the sugestion Paul, have done that now & the immeadiate thing i notice is that everything is lowercase, ie. garmin/poi/poi.gpi. Ihope this does the trick. Finger crossed!
Will keep you informed. |
Posted: Fri Dec 05, 2008 3:01 pm Post subject: |
Paul, you are a genius mate!
That worked a treat. All now fully loaded.
Thank you very much for all your help & effort. I am now a happy man!
Cheers! |
Posted: Fri Dec 05, 2008 3:18 pm Post subject: |
Now before you go away all happy can you tell me what I need to change on the guide to make it easier for the next person? _________________ Darren Griffin |
Posted: Fri Dec 05, 2008 4:44 pm Post subject: |
Of course I can. Only too pleased to. I've just changed a few things
Installing Pocket GPS Safety Camera Database - SD Card Models
1. Connect your card reader to the PC and insert the memory card .
2. If POILoader does not automatically start, run it now .
3. Select Garmin Device from Save Options. Click Next.
4. Your card reader should now be listed as the device. Click Next.
5. Choose Install new custom POI’s onto your device. Click Next
6. Browse for the folder where you saved and extracted the POI’s in Step 1. 'extracting the Database' above.
o NB: You MUST ensure you select Feet and mph if you are using UK/Northern Ireland files or Meters and km/h for all other countries (see below). If you do not ensure this selection is correct for your territory then the alerts will sound at incorrect speeds. This is the most commonly asked question, please check you have configured this correctly first.
7. Use Express (Recommended) mode to quickly transfer the database to your SD Card.
8. Note that any other POIs you wish to load must be uploaded at the same time as the Speed Camera database.
Thanks again! |
Posted: Fri Dec 05, 2008 4:52 pm Post subject: |
Appreciate it and glad you're all set to go. I've made the suggested edits to the guide. _________________ Darren Griffin |
Posted: Fri Dec 05, 2008 4:56 pm Post subject: |
Blimey Darren, that was quick. You guys are good! ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
Posted: Fri Dec 05, 2008 5:09 pm Post subject: |
aemdee - Glad to hear it's sorted. Weird thing is the case shouldn't matter as my i3 is GARMIN\Poi and the 760T is Garmin\Poi. Oh well... |
Posted: Mon Dec 08, 2008 5:48 pm Post subject: |
Maybe it's just the fact that the POI Loader writes directly to the SD card? Who knows? I'm just glad it works
So can I claim my free subscription for having my experience translated into the instructions to help other Kenwood users? ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
voiseya Occasional Visitor
Posted: Sat Mar 28, 2009 11:15 am Post subject: |
Hello I have exactly the same problem as aemdee, and the same system etc. I have tried all the suggested solutions here. The only difference I have is that I am using a Mac. So I am unable to try the 'fix' that worked for aemdee:
Quote
Unquote
On POI Loader for Mac, there is no option 'Garmin Device' only a drop down menu with 2 options 1) my SD Card Name and 2) 'Save GPI File to Computer'. There is also a button next to this named 'Find Device' but when you click this nothing happens. (Not surprising as there is no device)
Please can someone help me! |
Posted: Sat Mar 28, 2009 11:52 am Post subject: |
The easiest way for you appears to be to use the 'Save GPI File to Computer' option. Then set up a folder on the SD card called Garmin. Inside that folder make another called POI. Then copy the file to the POI folder on the SD card. Then use the SD card in your Kenwood unit...
Also looking back it appears all the folder names and filenames must be lower case.
ie. x:\garmin\poi\poi.gpi |
