Pocket GPS World :: View topic - Can someone walk me through reinstalling older app 8.010
garcor
Location: Nova Scotia & Florida in Winter Go 920 App 8.351 Maps NA 850 & C/W EU 830
PostPosted: Sun Nov 30, 2008 9:52 pm    Post subject: Can someone walk me through reinstalling older app 8.010 Reply with quote
The backup I had was 8.30 with 8.XX map ( prior to 8.15 ) thinking it was fine.
I am so fed up with the different buggs that are in the 8.30 app & or 8.15 map that I would like to go back to 8.010 app. and 8.xx map.
I downloaded the 8.010 app from Old Boys site but not quite sure how to install it to my unit. Is it just a matter of copying it to internal memory or is there something I need to do eg rename it etc. etc. or something ??
PostPosted: Sun Nov 30, 2008 10:07 pm    Post subject: Reply with quote
Have a read through This post which details what to do, the links in the thread are direct downloads from the server at TomTom, if you have the files from Richards web site they will work in the same way as detailed in the instructions - Mike
dhn
PostPosted: Sun Nov 30, 2008 10:24 pm    Post subject: Reply with quote
Mike, Garcor shows from his info that he has 8.15 maps installed. The link specifically says it won't work with 8.15 maps.
Garcor needs to move his 8.15 maps off his units, reinstall his earlier maps and THEN use the info in the link ... I think Confused
PostPosted: Sun Nov 30, 2008 11:34 pm    Post subject: Reply with quote
And if he has a backup with his previous "8.xx" maps, then that backup should also have the v8.15 software in it, so I'm not sure why he needs to download it from elsewhere.
If he doesn't have a backup of the previous map, he's stuck where he is anyway!
garcor
PostPosted: Mon Dec 01, 2008 2:35 am    Post subject: Reply with quote
Thanks Mike that is exactly what I wanted to do .
I was thinking my backup was app 8.15 and my map was 8.10 but
it so happened that it was App 8.010 (9369/040301) OS:1000
and map N/A 810.1907
I ended up formating my internal drive and then restoring backup with explorer.
everything is fine now.
I have the 8.15 N/A & C/W EU saved to a file on my computer .
When TT get the bugs worked out of the App & or Maps
I will reinstall
Thanks again
Gary
Go 920
App 8.35N/A Map 8.50
8GB SDHC card 8.30 C/W EU.
PostPosted: Mon Dec 01, 2008 8:56 am    Post subject: Reply with quote
You could put the new app and map on an SD card, insert the card and the device will boot using the card and the newer application, remove the card and the device will boot from the Flash memory - very handy when comparing different versions of software - Mike
garcor
PostPosted: Mon Dec 01, 2008 11:25 am    Post subject: Reply with quote
Thanks mike I might try that,,, I am just wating to see if TT will come out with an improved App shortly.
Gary
Go 920
22.055 (29 May 24)
