jonstatt Regular Visitor
Posted: Mon Nov 17, 2008 5:54 pm Post subject: |
MrT wrote: | I must admit I do think that some of the IQ routes information is just not good. One route I frequently do is far quicker on the dual carriageway (A1061 London Colney bypass and A414) that is very slightly longer in distance than the IQ route that takes me through a housing estate (London Colney) and a narrow country lane (White Horse Lane 51.73088 -0.28942) where the roads are narrow and have choke points where a parked car means only one car can pass at a time.
A stick to major roads option would be good. Also I assume that if I had an HGV it would still try and route me through the housing estates? |
The London Colney bypass is longer as you said, then say passing along London Colney high street. However, I would suspect the IQ routes ONLY exist for the bypass, and not for the high street. So I am guessing the TomTom assumes you maintain 30mph all the way along without having to slow down for road humps or bottlenecks.
I don't think it is very clear what roads are covered by the IQ routes, but I am suspecting major A roads and Motorways only. So if the TomTom is comparing a road that has IQ route data against one that doesn't...then you may or may not lose out in terms of optimal routes.
Another example...you mentioned the A414. As you go from London Colney towards the M25 or M1, there is often severe congestion on approach to the intemediary roundabouts. The Traffic HD system will correctly identify the traffic and it may suggest a back route that will bring you out through Bricket Wood. What the system fails to do is to have IQ Route data for that small road in Bricket Wood. If it did, it would avoid that road as there are bottlenecks there and the end of that route is almost impossible to turn out of.
We are a long way from perfect yet I'm afraid...each cycle brings about impressive feature names, but only incremental improvements. But it moves in the right direction. |
SQUARE2024 Lifetime Member
![](modules/Forums/images/avatars/gallery/familyguy9.jpg)
Posted: Tue Nov 18, 2008 1:19 pm Post subject: |
Just to add my bit on the map update saga,
I have updated and now running on 815.2003 with the 8.3 update on my 520.
all down loaded ok and last night had to put a route from Chelmsford to Morden in surrey via Hackney,all worked with no problems at all,[it used IQ route] voice guidance was clear,and the lane guidance on the M25 worked a treat !,of course in addition to this PWGPS kept me out of trouble with all the cameras. ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Square2024
TomTom 520
Christmas Draw 2010 Grand Final Winner Garmin Nuvi 1490TV |
Nogsx3 Occasional Visitor
Posted: Fri Jan 09, 2009 1:32 pm Post subject: |
I'm still on UK 675 maps as all the newer versions I've read on here weren't worth the update and often had less detail. Do 8.15 concidered an improvement on 675 ? That's about 2 years between gap between them...
I've got a TT one 3rd edition, 32mb ram....with a 2gb SD card
Andy_P Pocket GPS Moderator
Posted: Sat Jan 10, 2009 11:07 pm Post subject: |
"8.15 an improvement on 8.15 ?"
If you mean "is 815 an improvement over 675?", then in most places yes.
They will also have rather better POI collections and updated Postcode search. |
falkirk81 Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/1127958795496390ff66090.jpg)
Joined: Jul 07, 2006 Posts: 1649 Location: Newcastle, England, UK
Posted: Sat Jan 10, 2009 11:13 pm Post subject: |
For example, in the Newcastle upon tyne area, there are several new major junctions now on a couple of main roads which have only appeared since the last couple of map updates! _________________ Tomtom GO 1005 LIVE
iPhone 12 |
Posted: Sun Jan 11, 2009 12:09 pm Post subject: |
thanks andyp, sorry for my typo...corrected. Interesting.... I'll do an update then. |
brms Occasional Visitor
Posted: Sun Jan 11, 2009 9:56 pm Post subject: new maps |
I was looking at the new Teleatlas maps via Google maps (I assume they're the same). I live in Scotland, so was interested to see the new Mp spur south of the Forth Road Bridge is there, along with the new crossing at Kincardine. But between Nairn and Inverness there are two "new" roundabouts - been there for a few years now. One is now on the map, but the other - to the airport, with the new airport road (so quite a crucial feature for visiotirs) - still isn't there. This begs the question: how are these map changes picked up (or not) and why can one new feature be picked up but a nearby one not? |
Posted: Mon Jan 12, 2009 1:00 pm Post subject: |
Is the best time to subscribe to the "annual" map update subscription after the next map you want is released? Or do they only allow you access to the one "after" the current release when you subscribe? |
alanji Lifetime Member
![](modules/Forums/images/avatars/gallery/harrypotter4.jpg)
Posted: Mon Jan 12, 2009 1:28 pm Post subject: |
jonstatt wrote: | Is the best time to subscribe to the "annual" map update subscription after the next map you want is released? Or do they only allow you access to the one "after" the current release when you subscribe? |
You are obliged to upgrade to the current map (on a sliding scale cost) before you can subscribe to the annual map update. _________________ Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner
Posted: Mon Jan 12, 2009 1:32 pm Post subject: |
alanji wrote: | jonstatt wrote: | Is the best time to subscribe to the "annual" map update subscription after the next map you want is released? Or do they only allow you access to the one "after" the current release when you subscribe? |
You are obliged to upgrade to the current map (on aslidig scale cost) before you can subscribe to theannual map updare. |
Thanks for the reply..sounds a bit confusing.
If I go into TomTom Home right now, it is offering me a years subscription for 39.80 for Western and Central Europe. My thinking was I want to wait until the next map comes out before subscribing. I was trying to figure out the most economic route. |
Posted: Mon Jan 12, 2009 1:52 pm Post subject: |
jonstatt wrote: | alanji wrote: | jonstatt wrote: | Is the best time to subscribe to the "annual" map update subscription after the next map you want is released? Or do they only allow you access to the one "after" the current release when you subscribe? |
You are obliged to upgrade to the current map (on a sliding scale cost) before you can subscribe to the annual map update. |
It will not make a huge difference as you will have to pay an additional amount to upgrade to the newest map - see sliding sale here (I presume it is still current)
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=70657&highlight=annual+map+update
If you look up the price of your new map you can calculate how much it will cost you to upgrade to next quarters map (15% of cost). Whether it will take into account the current map discounts being offerred, I do not know but I suspect not. _________________ Alan
Dell Axim & TT3
Psion 5mx & Routeplanner |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Mon Jan 12, 2009 2:17 pm Post subject: |
If you subscribe now, you'll get v815 map immediately, and v820, 825 & 830 maps (or whatever the version numbers happen to be) during your year of membership.
If you wait till the next release (say v820) you'll probably also get v825, 830 & 835 when they are released during your subscription period.
If you can't find anything drastically wrong with your current maps, it may be slightly more economical to wait.
I only went for the update because the new map came with a new feature (IQ routes) that my previous map didn't have - I wouldn't have updated purely to get a more accurate map as the differences between versions often aren't significant. |
