Pocket GPS World :: View topic - no 7 didgit postcode
westentertainer
PostPosted: Sun Nov 09, 2008 5:32 pm    Post subject: no 7 didgit postcode Reply with quote
hello i have just downloaded tt 7 on my orbit 2 wm 6 ,i also downloaded a free city map just to try [all legal may i add ] but i noticed there is no 7 didgit post code facility ,does this only come with purchased maps...many thanks in advance
mpwilson99
PostPosted: Sun Nov 09, 2008 9:28 pm    Post subject: Reply with quote
You will probably need the .postal file
Depending on what your free map was, if it was in the UK or Netherlands it will work with the files contained in here...
http://www.tomtom.com/updates/zipcodes/map7/wezipcodes715.zip
Extract the files in the Zip to a folder called Zip on your MicroSD card.
Good Luck
westentertainer
PostPosted: Sun Nov 09, 2008 11:12 pm    Post subject: Reply with quote
thanks but there is no folder called zip on micro card ,only the cab ..is there somewhere else in the root i can make a folder?
PostPosted: Mon Nov 10, 2008 12:37 am    Post subject: Reply with quote
Using File Explorer on the PDA go to your storage card and create a folder called "zip" - put the postcode files from the download link provided by mpwilson99 into the folder named "zip and you will have full postcode search capability - Mike
westentertainer
PostPosted: Mon Nov 10, 2008 1:51 pm    Post subject: Reply with quote
ok is the zip s pelt with uppercase or lowercase thanks
PostPosted: Mon Nov 10, 2008 1:54 pm    Post subject: Reply with quote
zip all lower case - Mike
westentertainer
PostPosted: Mon Nov 10, 2008 2:20 pm    Post subject: Reply with quote
still not working
westentertainer
PostPosted: Mon Nov 10, 2008 2:37 pm    Post subject: Reply with quote
i connected device to HOME and displayed the content and it shows the zip folder with the postcodes !
ToonRocks
PostPosted: Tue Nov 11, 2008 9:52 am    Post subject: Cant use 7 digit postcode search Reply with quote
I had similar problem, the files in zip folder fixed, however did not work immediately as when I extracted zip folder to the Root directory, winzip created a zip folder within the zip folder !!
Bottom Line :- Just make sure you only have one zip folder in the root directory of your sd card, and that the two .ver files and the two .postal files are inside !!
Mine worked .... Good Luck
westentertainer
PostPosted: Tue Nov 11, 2008 3:13 pm    Post subject: Reply with quote
there is only one zip folder with postcode files inside on the root of my sd card and it still wont work,could it be that i have a free city map
mpwilson99
PostPosted: Tue Nov 11, 2008 3:34 pm    Post subject: Reply with quote
You never did say what city map you downloaded Question
westentertainer
PostPosted: Tue Nov 11, 2008 5:09 pm    Post subject: Reply with quote
it was Cardiff south wales sorry for any confusion
PostPosted: Tue Nov 11, 2008 5:50 pm    Post subject: Reply with quote
I am not too sure the city maps do support postcode search, although you might want to try moving the zip folder and its contents to the device memory where the TomTom folder is, this will consume around 10MB of memory on your phone though, but it might cure the issue unless as I suspect the map cannot deal with postcodes - Mike
westentertainer
PostPosted: Tue Nov 11, 2008 6:10 pm    Post subject: Reply with quote
thanks ,,how do i obtain maps for this ,i have tried home but there is nothing to tell me where to purchase,i would also like to have the speed cameras as well but if you cant open the map you cant
PostPosted: Tue Nov 11, 2008 6:18 pm    Post subject: Reply with quote
What version of Home are you using, try the latest release from the TomTom web site - Mike
