Flashyphotos Frequent Visitor
Joined: Nov 14, 2003 Posts: 306 Location: All Over The UK
Posted: Tue Nov 04, 2008 8:54 pm Post subject: x40 What Maps and whats the fuel card |
OK guys
Before I decide to buy
Can someone confirm
What map version is the 540 shipping with is it the current 810 version or is newer
and
Whats with the fuel card is it something in the box you can use at a major fuel chain or is it just markleting hype where you have to send off and register and maybe in 6 months get something!!!
Answers appreciated before card is swiped thru the till
Cheers |
SunnyUK Occasional Visitor
Posted: Tue Nov 04, 2008 9:09 pm Post subject: |
It's the 2nd. You have to find a secret number printed on the inside of the cardboard sleeve that the box is wrapped in. You then need to log this key on a website between 30 and 60 days from purchase. You then need to go fill up you car and send the receipt together with a print-out from the website in. Or at least that is how I understand it. Far from straight forward... but hey, for £50 one can survive having to do things the slightly long-winded way.
Of course, there's a risk that the website doesn't work. But naah, after all, it's TomTom, and they always test things well! |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Tue Nov 04, 2008 9:41 pm Post subject: |
According to others here, you register on the site, they send you a £50 fuel card which you use at your pleasure. There may be restrictions on which pumps you can use and you do have to register 30 - 60 days after purchase but it's a genuine offer. _________________ Darren Griffin |
Posted: Tue Nov 04, 2008 9:54 pm Post subject: |
Cheers Guys.
Appreciate the info on the fuel card.
Any news on the maps. Are they the standard V810 the same as the last update for the x30 series? |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Nov 04, 2008 11:31 pm Post subject: |
The maps may well be from the same data set but they contain the additional data for the revised IQ Routes (day/ hour rather than weekday/ weekend) - Mike |
uffe73 Frequent Visitor
Posted: Wed Nov 05, 2008 6:40 am Post subject: |
mikealder wrote: | The maps may well be from the same data set but they contain the additional data for the revised IQ Routes (day/ hour rather than weekday/ weekend) - Mike |
This is the information I would like someone to confirm. The extended IQ Routes don't work on a 720 with Navcore 8.2 and V810 maps, but an x40 might make a difference. |
Posted: Wed Nov 05, 2008 9:28 am Post subject: |
You will also need the other four digits of the map so IQ2 needs v810.1934 - Mike |
Guinness2702 Regular Visitor
Posted: Wed Nov 05, 2008 1:10 pm Post subject: |
Darren wrote: | According to others here, you register on the site, they send you a £50 fuel card which you use at your pleasure. |
Note: it is only £30 for the 540, which the OP mentioned. The 740 and 940 have £40 and £50 respectively. |
Posted: Wed Nov 05, 2008 8:42 pm Post subject: |
mikealder wrote: | You will also need the other four digits of the map so IQ2 needs v810.1934 - Mike |
Aha, is that the map version supplied with the new devices? Would be interesting to know the size of one of these V810.1934 maps comparing with it's corresponding V810.1907 map. If Mike's theory is correct the difference in size should be because of the new 24/7 data.
I would be most interested to hear someone if the routing with the enhanced IQ Routes data is any different from the regular one that only calculates based on weekday/weekend.
/Ulf |
hailstorm Regular Visitor
Posted: Wed Nov 05, 2008 11:41 pm Post subject: |
I hadn't even noticed a fuel card promotion was included when I bought it. Makes it that little bit cheaper. Hopefully get a little for my old TT One as well. |
