ssusan Occasional Visitor
Posted: Sat Oct 25, 2008 1:29 pm Post subject: DUFF TOM TOM 720 PLEASE HELP |
Hi i bought this TOM TOM 720 from Amazon
It says on the box TOM TOM 720 US CAN , I'm so disappointed as its a present for my OH , from the main menu there are some functions not highlighted and it wont get address from UK postcodes even though i have UK flag,
Is there any other option other than returning it to seller from Amazon.
Posted: Sat Oct 25, 2008 1:41 pm Post subject: |
Has it got a European or GB&ROI map loaded to it? - if not it won't be much use in the UK, the US spec units are shipped with North America mapping files installed, to check the map version tap the sat strength indicator lower right of the screen followed by the version box on the right of the next screen - Mike |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Sat Oct 25, 2008 1:42 pm Post subject: |
Can you navigate to any other UK address?
Does it have any UK or European maps on it? To check this tap the screen, select "Change preferences" then use the arrow to go to page 2. From there select "Manage maps" and then "Switch map". What map options do you see?
It could be that you are simply missing the postcode files, of course. _________________ Tim |
Posted: Sat Oct 25, 2008 2:06 pm Post subject: |
Thank you both.
map version-western europe-v710.1561.
western-europe.
hope this helps |
Posted: Sat Oct 25, 2008 2:10 pm Post subject: |
oh i should add from main menu ,find alternatice is greyed out and on page 3 clear route and view route are also greyed out |
Posted: Sat Oct 25, 2008 2:15 pm Post subject: |
Do you have a route planned? - if there is nothing planned then it cannot perform those functions so it greys them out - quite normal.
For postcodes can you try navigate to/ Address/ Postcode and see if it will let you enter the code from that screen? - if not the postcode files might be missing frm the device, these can be downloaded from Here - Mike |
Posted: Sat Oct 25, 2008 2:28 pm Post subject: |
ah, think I'm getting somewhere, thanks for your patience.
now when i go to postcodes and type in a six digit postcode there is no space bar and i can go no further.
I havent a clue how to install that file onto the ndevise can you help me on that also please |
Posted: Sat Oct 25, 2008 2:41 pm Post subject: |
You don't need the space bar for example entering FY4 3NN you simply type FY43NN and the device will accept it if you put that into your device it should offer a road (Kingsmede) - if you get that far you don't need the download as postcodes are working on your device - Mike |
Oldboy Pocket GPS Moderator
The Space Bar is not needed as the Postcode is input as AB101AF or EC1A1AH.
If you can do that and the first shows as Upperkirkgate then the Postcode Search is working correctly. _________________ Richard
Posted: Sat Oct 25, 2008 2:52 pm Post subject: |
Did that as suggested but when i put the full postal code in (my sons)ng95ph
underneath the postcode bar is just says ng9 |
Posted: Sat Oct 25, 2008 3:00 pm Post subject: |
hang on a minute....if i scrol down it comes up with different streets but not my sons.
Can you not just put a postcode in wuthout having to put street in next? |
Posted: Sat Oct 25, 2008 3:32 pm Post subject: |
It could be your sons postcode isn't actually part of the data set, I have seen this from time to time, try putting in FY43NN and what road does it say, all you do then is select the road followed by a house number - If you find the postcode you are using isn't on the device try using the Navigate to/ Address/ Street and House number option instead - Mike |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Sat Oct 25, 2008 3:41 pm Post subject: |
ssusan wrote: | Did that as suggested but when i put the full postal code in (my sons)ng95ph
When I input your son's postcode this is what I get
Is this what you get?
Edited to resize image _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Sat Oct 25, 2008 3:50 pm Post subject: |
Well thats close. its actually ribblesdale court.
Thank you for all your help i think without it i may have sent it back .
I'll have a play with it now
Ta Susan |
Posted: Sat Oct 25, 2008 4:04 pm Post subject: |
ssusan wrote: | I'll have a play with it now |
Before you play with it any more make a Windows backup on your pc by following the instructions at #1 in the FAQs here.
You should also read through the other FAQs in that list. _________________ Anita
UK map 1130.12368
