Pocket GPS World :: View topic - mapshare back now ?
mapshare back now ?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Stampy72
PostPosted: Sun Oct 12, 2008 8:06 pm    Post subject: Reply with quote
Still nothing for my TT One v2 running
v725.1883 map
2.4.0.104 of TT Home.
App 7.162 (8492/071121)
OS 2327
GPS v 1.21
Boot 5.5001
Although it DOES tell me, my Map is up to date, with 15727 MapShare map corrections in use...
mikero
PostPosted: Sun Oct 12, 2008 8:57 pm    Post subject: Reply with quote
Mine is now updated!
Go 730T
v8.010
Map Western & Central Europe 2GB v 810.1940
PostPosted: Sun Oct 12, 2008 9:42 pm    Post subject: Reply with quote
Praise the Lord!
map v715 W+CE updated at 21:20 - 12.5 MB of corrections.
Still being offered a v6 map!
But the Status indicator is now ONLY telling me newer versions of my map are available, no mention of how many MapShares in use.
How are others getting that info?
PostPosted: Sun Oct 12, 2008 10:03 pm    Post subject: Reply with quote
Answering my own question:
The Map status indicator was ONLY telling me newer versions of my map are available. Clicking on it gave me the details but no Mapshare corrections info.
I uninstalled it and re-installed it.
Briefly it now told me the number of Mapshares used , but also that my map is up to date. No mention of the subscription service.
I clicked around a bit and now it has reverted to the "newer versions of my map are available" display and no Mapshare info again.
Am I missing a trick?
falkirk81
PostPosted: Sun Oct 12, 2008 10:15 pm    Post subject: Reply with quote
Andy, to get the map update service, you need to go to the add maps section of tomtom home! it should give u a customised quote there and then! Smile thats how i did it!
Tomtom GO 1005 LIVE
iPhone 12
uffe73
PostPosted: Mon Oct 13, 2008 3:37 am    Post subject: Reply with quote
Andy, the map status indication plugin isn't very well designed, which you have witnessed here. It doesn't provide any MapShare details unless you have the latest map release installed. If you have an older map release, it will ONLY keep telling you there's a newer map available, no mentioning of the number of MapShare map corrections being in use. Let's hope TT releases a new version of the plugin soon that addresses this!
Regards, Ulf
maca2
PostPosted: Mon Oct 13, 2008 8:09 am    Post subject: Reply with quote
uffe73 wrote:
maca2, it would help if you stated for which map you're trying to download map corrections. MapShare has not yet been reactivated for all maps.
Regards, Ulf
My map is 8.010
PostPosted: Mon Oct 13, 2008 8:25 am    Post subject: Reply with quote
Maca2, the 8,010 is the software application version number, the map will be slightly different, possibly v810 - Mike
maca2
PostPosted: Mon Oct 13, 2008 8:55 am    Post subject: Reply with quote
Sorry Mike didn't know that
My map is V805.1801
maca2
PostPosted: Mon Oct 13, 2008 10:25 am    Post subject: Reply with quote
At last Mad
My mapshare is now all working & has downloaded 3mb's of updates.
Razz
Stampy72
PostPosted: Mon Oct 13, 2008 10:49 am    Post subject: Reply with quote
Still nothing here....
dave-t
PostPosted: Mon Oct 13, 2008 11:50 am    Post subject: Reply with quote
maca2 wrote:
At last Mad
Razz
Yep my V8.010 maps had a small update yesterday
TT 530, TT 510, SPOT, Quo2, SatMap Active 10
PostPosted: Mon Oct 13, 2008 2:39 pm    Post subject: Reply with quote
Sorry, that's not what I was after... I just want to be able to see the MapStatus indicator in BOTH it's modes (i.e. Showing how out of date my base map is and showing the number of mapshare corrections in use. As I said, I have seen it do both, I just haven't worked out the trick of getting it into either mode.
All I can say is that while I was fiddling last night, I DID get it to show the Mapshare corrections briefly, just after I re-installed it. I just can't make it do it again!
mikentl
PostPosted: Mon Oct 13, 2008 3:46 pm    Post subject: Reply with quote
Working fine for me too, I now have countries showing and have downloaded 13000+ mapshare updates
Regards Mike
dhn
PostPosted: Mon Oct 13, 2008 3:51 pm    Post subject: Reply with quote
Andy, do you have maps on both internal and sd card? If so, when you have, say, internal selected in Home, what does the map indicator show? Then, select the external using Home and what does the map indicator say when you select Update again?
Page 6 of 9
