Pocket GPS World :: View topic - TT1 v3 Update Problem
mikeshe
PostPosted: Sun Oct 05, 2008 5:05 pm    Post subject: TT1 v3 Update Problem Reply with quote
I've been trying to update using TTHome and once Home starts and does the checking I keep getting the following error message come up:
ERROR: HomeBase/Unknown: Unknown exception has been caught.
@ .\framework\DeviceItemScannerThread.cpp(75)
bad allocation
in .\framework\DeviceItemScannerThread.cpp:75
Stack:
0. function errorAbortTask chrome://tthome/content/logic/ttTask.js:424
error(e);
1. function error chrome://tthome/content/ui/bindings/ttwizard.xml:1157
else if (errorNonFatal)
2. chrome://tthome/content/ui/bindings/ttwizard.xml:528
Time: Sun, 05 Oct 2008 16:01:08 GMT
Anyone have any ideas what's wrong and how to get round it?
Thanks.
dhn
PostPosted: Sun Oct 05, 2008 5:08 pm    Post subject: Reply with quote
My initial thought would be to uninstall Home, log directly into TomTom.com with your account id (email address), dl and reinstall Home.
PostPosted: Sun Oct 05, 2008 5:10 pm    Post subject: Reply with quote
Delete the TomTom Home application from your PC and try downloading/ installing a new copy from This web page, download using the large green button on the left for the device you have got - Mike
mikeshe
PostPosted: Sun Oct 05, 2008 5:50 pm    Post subject: Reply with quote
Thanks lads, done as you said..... still getting errors.
PostPosted: Sun Oct 05, 2008 5:52 pm    Post subject: Reply with quote
What OS are you using on your computer?
mikeshe
PostPosted: Sun Oct 05, 2008 5:53 pm    Post subject: Reply with quote
Windows XP.
PostPosted: Sun Oct 05, 2008 5:57 pm    Post subject: Reply with quote
And did you fully uninstall via Control Panel and then reboot before installing again?
HOME is terribly bug ridden and the cause is almost certainly the application itself not playing nicely on your system. If the above doesn't work then the only thing I can suggest is reverting to an earlier release of HOME until TomTom fix the issue.
mikeshe
PostPosted: Sun Oct 05, 2008 6:09 pm    Post subject: Reply with quote
Thanks Darren, I did uninstall via the Control Panel but didn't reboot. So I just done it properly but it's still coming up with the error.
dhn
PostPosted: Sun Oct 05, 2008 6:16 pm    Post subject: Reply with quote
Errors after uninstalling AND reinstalling?
If yes, did you go to the link provided to get the firmware? The compressed file on your computer may be corrupt.
mikeshe
PostPosted: Sun Oct 05, 2008 6:25 pm    Post subject: Reply with quote
I've tried it from the link which didn't work so I deleted it then I connected the TT and let that dload and install it, still with errors.
dhn
PostPosted: Sun Oct 05, 2008 6:36 pm    Post subject: Reply with quote
Are you using a wireless router/modem when you download? If so, try a direct connection and see if it helps.
You may also want to try to connect your unit using a different usb port, preferably on the back of your computer.
carl_the_cobbler
PostPosted: Sun Oct 05, 2008 7:17 pm    Post subject: Reply with quote
Hello,
As Darren suggested about installing a previous version.
Someone else has had this problem on another forum and they reinstalled V2.2 and the problem disappeared.
This
Stack and bad allocation sometimes mean memory problems.
This could be an issue if your PC is ageing.
Carl
P.S.Try here for HOME 2.2 if you feel you need it
http://www.oldboy.me.uk/TomTomUpdates/
Last edited by carl_the_cobbler on Sun Oct 05, 2008 7:20 pm; edited 1 time in total
mikeshe
PostPosted: Sun Oct 05, 2008 7:20 pm    Post subject: Reply with quote
Well I kept deleting and reinstalling and eventually it works okay now!
Computers? I hate the bloody things!!
eduo
PostPosted: Sun Oct 12, 2008 7:45 pm    Post subject: Reply with quote
It's a shame this was never solved. TTH has the same issue on my Mac and my TomTom Toyota.
(I know it was solved, I meant no solution was found, it just simply started working). This and a page in italian are the only places I've seen this reported.
carl_the_cobbler
PostPosted: Sun Oct 12, 2008 11:34 pm    Post subject: Reply with quote
I reckon it is to do with the age of the computer you are running home on, or maybe the type of memory installed, the first question I would ask is the Operating System version then is it from PC World or another similar shop.
22.105 (30 Oct 24)
