nashmills Regular Visitor
Posted: Thu Sep 25, 2008 9:36 am Post subject: Go 520 line-out interference |
Can anyone advise on this problem please?
I have my Go 520 in a Brodit active mount and want to use a stereo cable from the line-out socket on the TomTom to the aux input on my car stereo.
It all works OK but I get some distracting interference when the Brodit is also plugged into the car's power socket. |
KerrAvon Occasional Visitor
Posted: Thu Sep 25, 2008 10:02 am Post subject: |
try using one of them suppressors you can get in maplins ( the onles that you can surround the cable with ... my local branch has them on the stand next to the gps stuff |
Posted: Thu Sep 25, 2008 10:21 am Post subject: |
KerrAvon wrote: | try using one of them suppressors you can get in maplins ( the onles that you can surround the cable with ... my local branch has them on the stand next to the gps stuff | Thanks, I will look into that. Is that to surround the power cable? |
Posted: Thu Sep 25, 2008 10:22 am Post subject: |
What you need is a ground loop issolator which plugs in between the TomTom and the car audio input, Maplins and Halfords sell these for around 8 quid, although it uses RCA audio sockets so don't forget to grab some RCA to 3.5MM jack plug leads while you are at the store - Mike |
Posted: Thu Sep 25, 2008 10:34 am Post subject: |
mikealder wrote: | What you need is a ground loop issolator which plugs in between the TomTom and the car audio input, Maplins and Halfords sell these for around 8 quid, although it uses RCA audio sockets so don't forget to grab some RCA to 3.5MM jack plug leads while you are at the store - Mike | Is it the audio lead? If I run the setup without the power plugged in there is no interference at all. It's only when I plug in the power lead from the Brodit that it starts. |
Posted: Thu Sep 25, 2008 10:42 am Post subject: |
This is a well known problem with some cars and is caused when the electical connection is made between two powered devices, in this case the audio lead causes current to flow between the two devices which in turn creates the interference. The ground loop issolator allows the audio signal through but blocks the DC component thus preventing the interference - Mike |
Posted: Thu Sep 25, 2008 10:49 am Post subject: |
Thank you - I'll go shopping later. |
Posted: Thu Sep 25, 2008 11:36 am Post subject: |
That will do the trick and far cheaper than at the shops - Mike |
Andy_P Pocket GPS Moderator
Posted: Sat Sep 27, 2008 10:14 pm Post subject: |
...and has even got the right connectors already, so no adapter leads required.  |
SatMonkey Lifetime Member
Posted: Tue Sep 30, 2008 10:18 pm Post subject: |
I get an alternator-style noise if I use the AUX in ... would this cure it?
Let me know if it works ... coz I need one of these too!
Thanks! |
Yes, this will cure the problem - Mike |
Posted: Thu Oct 02, 2008 4:52 pm Post subject: |
Received today. Just tried it and it works fine. Thanks Mike.
Only problem now is the weak output of the GO. I need to have the car stereo volume up very high and remember to turn it down before switching to the radio or CD player. |
Posted: Thu Oct 02, 2008 4:58 pm Post subject: |
Are you still on v7 software?
In v7, the overall volume control affects both the navigation voice and the mp3 player.
In v8, the mp3 player volume is fixed at 100% irrespective of the normal volume control setting - that's certainly the case for the FM and Bluetooth output and I think it is so for the line out too. |
Posted: Thu Oct 02, 2008 5:19 pm Post subject: |
I am using v8 software. I've just checked and the mp3 player was showing 80% volume. I've changed it to 100% and will try that next time. |
