Spacer Occasional Visitor
Joined: Jan 02, 2006 Posts: 21 Location: Nr Birmingham, England
Posted: Tue Sep 23, 2008 7:43 pm Post subject: 720 8.10 map problem with ALG |
Hey all. Just bought the new map/update package. Everything installed ok, but the ALG won't enable in the menu. It just says either the software or firmware aren't compatible. Any ideas? Thanks in advance |
Posted: Tue Sep 23, 2008 7:57 pm Post subject: |
As an update, I've tried a soft reset, and tried removing both the latest software (and bizarely it now takes me back to 7.481 during an update), and I'm trying to reinstall the map (8.10) to see if it works. Now updated again to 8.010 to see if it makes any difference, and about to re-add the maps back to the tomtom.
john877 Lifetime Member
Posted: Tue Sep 23, 2008 8:02 pm Post subject: |
What software version have you got on your sat nav |
Posted: Tue Sep 23, 2008 8:09 pm Post subject: |
Just re-updating (if that's a word!) back to 8.010. It had it on, but I thought I'd remove it and let it re-download it. |
Posted: Tue Sep 23, 2008 8:23 pm Post subject: |
The 7,481 update is required BEFORE Home will install the version 8,010 software so what you are experiancing is quite normal - Mike |
Posted: Tue Sep 23, 2008 8:27 pm Post subject: |
Mike, sorry if I wasn't clear. I did have 8.010 installed before. It wouldn't enable the ALG in the change prefs menu. Then I removed it and the map, and tried updating (stage by stage) to get me back to 8.010. I have 8.10 maps which have been freshly downloaded tonight. |
Posted: Tue Sep 23, 2008 8:34 pm Post subject: |
Try tapping the sat strength meter (lower right corner) followed by the version box - does the map that is listed contain the 8,010 code number? - If not go to Change Preferences/ Manage Maps/ Switch Map and select the new map - it could be you have two different maps installed to the device - Mike |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Tue Sep 23, 2008 8:36 pm Post subject: |
Spacer wrote: | Mike, sorry if I wasn't clear. I did have 8.010 installed before. It wouldn't enable the ALG in the change prefs menu. Then I removed it and the map, and tried updating (stage by stage) to get me back to 8.010. I have 8.10 maps which have been freshly downloaded tonight. |
Curious.......are you trying this with the unit docked or on battery power? _________________ David |
Posted: Tue Sep 23, 2008 8:44 pm Post subject: |
Ok, I have it working now. I simply had to delete the map and software off the device, and update the device twice (to get back to 8.010 software) and then copy the map back across. Odd, and not the slickest installation of an update. |
